Pocket GPS World :: View topic - Safety Camera (UK) alarm does not sound
Goto page 1, 2, 3  Next
nickmon
PostPosted: Sat Aug 26, 2006 1:57 am    Post subject: Safety Camera (UK) alarm does not sound Reply with quote
Even though I have set an alarm for the UK Safety Cameras when I pass them by, nothing happens; why is this?
When I checked the preferences and clicked on the Saftey Cameras it says oddly, "remove warning", as if by default thewre is already a warning selected, and yet I hear nothing.
PostPosted: Sat Aug 26, 2006 7:25 am    Post subject: Reply with quote
2 things spring to mind.
Have you got the sound turned down, or muted?
Did you tick the Option to 'Warn Only if POI is on Route' and wasn't using a Route?
davidbeaty
PostPosted: Sat Aug 26, 2006 7:43 am    Post subject: Reply with quote
I had this also when I upgraded to 6.14 recently.
I rectified it by just going through the process of resetting them all up.
Note: I had to remove the "warn when near POI" then re add them all again. worked perfectly after.
________________________________________
TT One (V1) + 1Gb SD Card
Sony K750i on Orange PAYG
pocket GPS camera POI + real voice warnings
Legohead
PostPosted: Sat Aug 26, 2006 11:46 am    Post subject: Reply with quote
I had a similar thing on my TT 510 after an automatic update, not sure if it updated the camera database, but afterwards if I selected 'Polite 2' the unit would not sound when approaching a camera, select the more annoying Nokia style Polite 1 and it would work........ very odd Confused
nickmon, when it displays remove warning, have you tried selecting 'no' to progress to the next few screens and select a different tone??
Kenwood KVT627 linked to KNA-G520 nav
Garmin GPSMAP 60C
nickmon
PostPosted: Sun Aug 27, 2006 1:47 am    Post subject: Let me explain... Reply with quote
The problem seems to be that the "40" sign for the speed camera (which should say '30') seems to be a bit further back from the roadside on the map, and presumably therefore does not activate the alarm. It's the wrong speed in the wrong place.
TomDavison
PostPosted: Sun Aug 27, 2006 9:26 am    Post subject: Reply with quote
Is this just on the one camera then, or do you have this problem with all cameras?
nickmon
PostPosted: Sun Aug 27, 2006 5:17 pm    Post subject: Well it appears to be just this one... Reply with quote
I got out and tested my TomTom right away and this is the speed camera nearest me, and I find it gives inaccurate infromation. If there was a way of photohraphing it i'd let you see it.
PostPosted: Sun Aug 27, 2006 5:40 pm    Post subject: Reply with quote
nickmon, could you please specify the offending camera ID so someone can take a look at this, go to the Browse Map funtion, zoom in to the location where the camera is and tap it, this will bring up the ID of the camera.
This is far easier than photographing the device in use and gives more information.
In addition to the camera ID can you please specify what Icon was dispalyed on the screen in terms of speed, and the allert issued by the device (assuming you are using spoken alerts), with this information we might be able to shed some light on the issue - Mike
bennyk
PostPosted: Tue Aug 29, 2006 3:40 pm    Post subject: mising alerts Reply with quote
Guys
I have the same problem here with a few cameras that no warning appear at all.
They are:-#
Mobile 11382@50
Mobile 16120@50
Mobile 15029@50
Mobile 18008@50
Hope that helps
bennyk
PostPosted: Tue Aug 29, 2006 4:29 pm    Post subject: warn Reply with quote
mobile 15842@70 does not warn either
cleanbloke
PostPosted: Sun Sep 03, 2006 12:42 pm    Post subject: Reply with quote
WARNING TO OTHERS!!!!!!
i have just come back from the yorkshire dales to essex along the A1 and started to notice by chance that a 70-mobile on a bridge and a few 70-cameras had the icon warning me but no spoken warnings, checked settings and everything seems fine. sorry i can't give you the actual camera points. I'M HOPING I WASN'T CAUGHT OUT............
Grrrr
Antoeknee
PostPosted: Sun Sep 03, 2006 6:56 pm    Post subject: Reply with quote
Since I've changed to spoken warnings I'm seeing 2 issues.
Even though 'warn on route' is ticked I recieve warnings for some cameras that are not and have recieved no warning for one camera.
As far as I can recall this was not a problem when I use the consolidated by type DB.
PostPosted: Sun Sep 03, 2006 9:34 pm    Post subject: Reply with quote
Using V6.xxx by any chance?;)
There is a bug in V6 that if consecutive POI Warnings are the same, without a direction instruction between them, only the first will be announced.8O
999tommo
PostPosted: Sun Sep 03, 2006 10:44 pm    Post subject: Reply with quote
Oldboy,
Do you mean that if you are not navigating to anywhere in particular, and you pass one 30mph camera you will get the usual warning, but if you then pass a second 30mph camera you will not be warned of it ? If so, then this is not just a bug but it affects the whole point of the speed camera database and PGPSW need to get onto Tom Tom to get this corrected pronto !! I'm sure I read in a previous post somewhere that people who had TT x10s were putting in double warnings for each camera so that each second warning could be safely ignored without affecting the operation of the device.
Tommo...
Regularly absent, but still here in spirit !
PostPosted: Sun Sep 03, 2006 10:59 pm    Post subject: Reply with quote
That is exactly what some of us are doing, and it works - I must admit I thought the problem was confined to the Text To Speach (TTS) and therefore only the Go-910 unit was affected, but perhaps not, I don't have another device on which to try this (shame as Blackpool makes an easy test for the problem to present itself within 2 miles of home) - Mike
Page 1 of 3
