paulthetool Occasional Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_013.gif)
Joined: Nov 21, 2005 Posts: 45 Location: Clacton on sea, Essex
Posted: Sun Aug 20, 2006 5:48 pm Post subject: Upgrade tomtom go ?? |
Hi all,
My brother has just gave me his old TomTom GO as he has upgraded. He said that I may be able to get a upgrade
to allow me to do full postcode search ?
How do I get this upgrade
Many thanks
Paul
paulyoung04@aol.com |
TonyHoyle Regular Visitor
Posted: Sun Aug 20, 2006 7:13 pm Post subject: |
Which model? Most of them already have it.
If your model doesn't I doubt you can legally add it. |
Posted: Sun Aug 20, 2006 7:23 pm Post subject: version reply |
On the bottom on the unit:GO (4D00.001)
on screen:
Device AK3SL A2DSE
App 4.420 (2852/041010)
OS: 201
GPS v1.21
hope this is the info you need?
Paul |
Posted: Sun Aug 20, 2006 7:28 pm Post subject: |
Probably an original GO. Version 4.4!!! Probably never been updated...
The first thing you need to do is to update to something vaguely recent. 5.440 or 6.15.
As to whether it's possible to get postcode search on that model I'm not sure. |
Posted: Sun Aug 20, 2006 7:32 pm Post subject: |
The[i] first thing you need to do is to update to something vaguely recent. 5.440 or 6.15. [/i]
Is this a free upgrade or pay for?
where di I get the files from ??
Paul |
Posted: Sun Aug 20, 2006 7:59 pm Post subject: |
The upgrade is free you can get it from HERE - before you start doing any of this make sure you have a full back-up of the card on your device, without this if it all goes wrong there is no way to recover the situation.
The upgrade will only give you the new program, it will not load the postcode data as this is a seperate file contained in the map, map upgrades would include this - these cost money - Mike |
sgould Frequent Visitor
![](modules/Forums/images/avatars/12745715643c17d95b9699.jpg)
Posted: Sun Aug 20, 2006 9:04 pm Post subject: |
The original GO has a small 128MB card and the new system may overfill it. It should have room if you delete some foreign voices. but the best thing would be to buy a bigger SD card and copy the original card to it before you play wiht the upgrade.
You may be one of the lucky ones that has a CD with backup copies of the maps. You can fall back on this if you have problems, but a full backup copy of the card should be made to a folder on your PC as it's easier.
Also the original Go came with a separate map of the main roads of Western Europe on the CD. You could copy this to a bigger card as well as the GB map. _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
Posted: Sun Aug 20, 2006 9:33 pm Post subject: updated ? |
Thanks for all the info so far.
I now have version 6.150 installed but this still only allows
me to search part postcode
I do have tomtom on my PDA hat has full postcode search
Is there any files I can use from my PDA or TT5 CD to give
me full postcode search now?
Thanks in advance
Paul
TM Occasional Visitor
Joined: Jul 19, 2005 Posts: 30 Location: Stonehouse, Glos.
Posted: Tue Aug 22, 2006 12:27 pm Post subject: |
The full postcode search was added to the original Go when the maps were updated.
To get this you wil have to buy updated maps as the postcode database is licensed. |
Posted: Wed Aug 23, 2006 7:48 pm Post subject: |
As i have the FULL TomTom5 for use on my PDA and am going to stop using the PDA and put the files on the GO there is no software copyright problems..
So what files do I put where ??
Paul
TuurG Frequent Visitor
![](modules/Forums/images/avatars/350681644c94264ae694.jpg)
Joined: Nov 23, 2004 Posts: 454 Location: Haarlem, The Netherlands
Posted: Wed Aug 23, 2006 9:25 pm Post subject: |
IF you remove the software from the PDA, you are allowed to use it on your GO, provide you have not activated twice in the last 180 days.
It's easiest to stick your TT5 SD in your GO (or install everything from the TT5 CD if you have the CD set with maps), and then install GO app 6.15 on it. Then start up teh GO, and enter your new activation code. _________________ GO1005
MGC GT 1968
MGB Cabrio 1973 |
joedavid0 Occasional Visitor
Posted: Sat Sep 02, 2006 10:36 am Post subject: |
sgould wrote: | The original GO has a small 128MB card and the new system may overfill it. |
What size should the repacement be, please?
David |
Tumbleweed Frequent Visitor
Posted: Sat Sep 02, 2006 10:41 am Post subject: |
joedavid0 wrote: | sgould wrote: | The original GO has a small 128MB card and the new system may overfill it. |
David |
256 will do, 128 is also in the new models but space is very tight. If you ever intend to buy other maps, then a bigger card might be worth getting, not much difference in cost
tw |
Posted: Sun Sep 03, 2006 7:48 pm Post subject: |
mikealder wrote: | The upgrade is free you can get it from HERE - Mike |
The link gets me a TomTom blank page.
Regards
David |
Posted: Sun Sep 03, 2006 7:56 pm Post subject: |
The link worked when I posted it, it would appear the tomtom web site is undergoing maintenance so when it is back up the link may or may not work - will have to try again later, when the site is put back on line - Mike |
