dumbodick Occasional Visitor
Posted: Thu Jul 06, 2006 12:09 pm Post subject: copying favorites on TOM TOM |
I am using Tom Tom on another memory card on my PDA. I need to copy the favorites information from another system, is there a file i can bring across that has this info. It must be stored on the storage card somewhere but i cant find it.
regards DB |
hope68 Regular Visitor
![](modules/Forums/images/avatars/148172454944a42f6a1bed4.gif)
Posted: Thu Jul 06, 2006 1:33 pm Post subject: Re: copying favorites on TOM TOM |
dumbodick wrote: | I am using Tom Tom on another memory card on my PDA. I need to copy the favorites information from another system, is there a file i can bring across that has this info. It must be stored on the storage card somewhere but i cant find it.
regards DB |
Hiya,
yes, you have to copy the xx-map.cfg file to the other storage card.
cu Peter |
julianbarker Lifetime Member
Posted: Thu Jul 06, 2006 1:35 pm Post subject: |
The best thing to do is always use a POI category instead of favourites as favourite info is easily lost and not easily moved from machine ot machine. The best thing is to create a POI category, move al lyour favourites to it, then move the POI file (the OV2 file with the same name as the category) to the other device. If you want to then convert the POIs back to favourites you can do, but you are more likely to lose the data if TT ever has problems reading the card. |
Posted: Thu Jul 06, 2006 2:30 pm Post subject: |
Sorry, what is difficult when you copy and paste a file?
I also have a copy of my xx-map.cfg-fiel on my sd-card (and also on my pc). if the cfg-file ever gets corrupt - then i just copy and paste it into the map-file and i have the favorites, home etc. again.
cu Peter |
Posted: Thu Jul 06, 2006 2:40 pm Post subject: |
thanks loads for the info, this site is so usefull.
db |
Oldboy Pocket GPS Moderator
Posted: Thu Jul 06, 2006 6:57 pm Post subject: |
hope68 wrote: | Sorry, what is difficult when you copy and paste a file? | The problem arises when there is an upgrade in Major Versions. Sometimes the cfg File is not compatible with the new Version.
Another advantage of using a Favourite POI is that it can be used on any TT and, with the POI Conversion Tools that are available, converted for use on most PND that have the capability to use custom POI. _________________ Richard
Posted: Thu Jul 06, 2006 8:49 pm Post subject: |
Oldboy wrote: | hope68 wrote: | Sorry, what is difficult when you copy and paste a file? | The problem arises when there is an upgrade in Major Versions. Sometimes the cfg File is not compatible with the new Version.
Another advantage of using a Favourite POI is that it can be used on any TT and, with the POI Conversion Tools that are available, converted for use on most PND that have the capability to use custom POI. |
Thx for the info
cu Peter |
sHaRpEy Occasional Visitor
Posted: Thu Jul 06, 2006 9:32 pm Post subject: |
Superb! Thanks for the info. TomTom is cos once you create a favourite you can't see the address of GPS position data. Unless someone knows something I don't? ![Confused](modules/Forums/images/smiles/icon_confused.gif) |
Posted: Thu Jul 06, 2006 10:21 pm Post subject: |
sHaRpEy wrote: | cos once you create a favourite you can't see the address of GPS position data. | I don't understand what you're asking for.
What do you want to achieve? _________________ Richard
Posted: Thu Jul 06, 2006 10:37 pm Post subject: |
Well if you've added a favourite, but later you won't to know the detials, ie: address/postcode you are unable to see this information. Only options are to rename or delete. |
Posted: Fri Jul 07, 2006 7:17 am Post subject: |
You could put those details in the Text when you originally name the Favourite.
If it is a Favourite, would you need to know the extra information? _________________ Richard
vocaro Occasional Visitor
Posted: Thu Jul 20, 2006 12:21 am Post subject: How to extract GPS coordinates from TomTom Navigator 5 |
Hope this helps. |
neil01 Frequent Visitor
![](modules/Forums/images/avatars/gallery/118.gif)
Posted: Thu Jul 20, 2006 5:48 pm Post subject: |
Oldboy wrote: | ...If it is a Favourite, would you need to know the extra information? |
Perhaps not for you, but you may be using collected favourites from several sources to create a POI file for everyone. Deliveries springs to mind as an example. |
Pedro-G Occasional Visitor
Posted: Tue Jul 25, 2006 10:55 pm Post subject: |
In case someone is interested, I just changed my old Scandinavia map to the Scandinavia Plus (v632). I managad to rescue my favourites by copying the .cfg file. Naturally I had to rename it to "_Plus-Map", but it was still compatible.
The only thing I lost was my Home address, but it took about 2 seconds to re-enter that...
However, going with a POI category instead of favourites sounds good, I might do that. |
