Pocket GPS World :: View topic - Suction failing - is it the hot weather???
sfcman
PostPosted: Thu Jun 08, 2006 7:02 pm    Post subject: Suction failing - is it the hot weather??? Reply with quote
Don't know if it is the hot weather, or if my suction mounting thing is just getting tired, but is anyone else having problems keeping the mounting stuck to the windscreen. I have had my I3 since last September, & it usually falls off the windscreen about once a month or so, but at the moment I can hardly keep it in place for 5 minutes. Have tried cleaning suction cup & windscreen, but little improvement.
Dilcymro
PostPosted: Thu Jun 08, 2006 8:02 pm    Post subject: Reply with quote
sfcman said,
I take it you have moistened it a bit before applying to the windscreen.
Dil.
Garmin Nuvi 2415
Where there`s a Dil ---- There`s a way
timber
PostPosted: Thu Jun 08, 2006 10:29 pm    Post subject: Re: Suction failing - is it the hot weather??? Reply with quote
Try smearing a small amount of vaseline on the suction mount remember that this will leave a very distinctive mark when removed but should hold better to the glass.
The temperature in the sun that the black suction cup goes up to must be immense. On Fire
alan_t
PostPosted: Thu Jun 08, 2006 10:41 pm    Post subject: Reply with quote
abit of spit goes along way.
sfcman
PostPosted: Fri Jun 09, 2006 8:16 am    Post subject: Reply with quote
Thanks for the replies. Have tried licking it, but not much better. Will try vaseline & let you know!
oddsock
PostPosted: Fri Jun 09, 2006 10:05 am    Post subject: Reply with quote
Might not vaseline which is made from oil degrade the material in the sucker???
TomTom one v1,tomtom one v 3,TT Start20,Garmin Oregon 300,Nuvi 300
Garmin Quest
BERT_UK
PostPosted: Fri Jun 09, 2006 10:23 am    Post subject: Reply with quote
I'd say it's the heat.
I noticed in the winter that when I had the car's heater on with the setting for them to clear the windscreen then when the temperature got too hot the suction cup would give up and fall off. Changing the heaters direction from the windscreen solved this problem...unfortunately you can't do that with the sun! On Fire
I guess you could try using the car's heaters on the cold setting with them directed on the windscreen to try and counteract the heat in the summer. I think you could be fighting a losing battle unless you have A/C though Confused
slartibartfast
PostPosted: Fri Jun 09, 2006 10:35 am    Post subject: Reply with quote
I think it depends on the shape of the windscreen as well. With my last car the i3 fell off quite regularly when it was in the bottom right hand corner of the windscreen. My new car has a flatter windscreen and it is a lot more difficult to remove the suction mount and the problem has gone away. I know it it doesn't really help in solving the problem, just an observation.
Mr_Gonzales
PostPosted: Fri Jun 09, 2006 12:47 pm    Post subject: Reply with quote
First all this talk about my balls, now it's moved on to vaseline and licking and the like. Where will it all end? 8O
nudda
PostPosted: Fri Jun 09, 2006 9:49 pm    Post subject: Reply with quote
check for CRACKS in the suction cup from hot weather
ok ok thats kinda skipping the line Laughing Out Loud
newtosatnav
PostPosted: Fri Jun 09, 2006 10:16 pm    Post subject: Reply with quote
The best thing to use is a TINY bit of fairy liquid.
225man
PostPosted: Sun Jun 11, 2006 2:19 pm    Post subject: Reply with quote
Hi, I have found the complete opposite, I wanted to switch my I3 to another car & couldnt get the mount off the windscreen!
I tried heat, ac on full cold setting, still no joy. In the end I had to use brute force which resulted in bits of the rubber sucker left stuck to the windscreen!! Just like I had used super glue to mount it!
I will phone Garmin tomorrow to see i can get a new 1 under warranty (unit only 3 weeks old),
Does any one know where I can buy a new mount?
Anita
PostPosted: Sun Jun 11, 2006 2:30 pm    Post subject: Reply with quote
£13.99 delivered from here:
http://www.globalpositioningsystems.co.uk/garmin-vehicle-suction-cup-replacement-for-streetpilot-i-seriesnuvi-description.html?PHPSESSID=d8774e8ae7bc9ac4bc5604f9cc5100df
Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21
typan
PostPosted: Sun Jun 11, 2006 6:47 pm    Post subject: Reply with quote
I had the same problem, sent Garmin an email and they said they would replace it. about a week ago, don't know how long it's going to take though !
mikemccafferty
PostPosted: Mon Jun 12, 2006 11:51 am    Post subject: Reply with quote
TRY CLEANING THE MOUNT AND THE SECTION OF WINDSREEN
WITH T-CUT OR SIMILAR PRODUCT BUT NOT CAR POLISH
