Pocket GPS World :: View topic - Speed indication?
Speed indication?
gassy
PostPosted: Tue Nov 18, 2003 10:28 am    Post subject: Speed indication? Reply with quote
I'm a complete newbie to both GPS and Pocket PC. I'm very pleased with the Aldi package, and I've also downloaded the POI-Warner software.
I know that some GPS systems can show your road speed, and although I know my SAAB speedo is very accurate (1% - tested on a rolling road) I would be interested to find out what Medion - Navigator thinks it is. But this doesn't seem to be a display/programme option.
Am I missing something? Or do I need to buy another piece of software?
Roy
PostPosted: Tue Nov 18, 2003 5:29 pm    Post subject: Reply with quote
I would like to know aswell. My speedo is out due to bigger wheels being installed. I thought it would be on the program but can't see it like you say
aero
PostPosted: Wed Nov 19, 2003 8:56 pm    Post subject: Reply with quote
Will any of the utilities on this page give a speed indication?
http://www.pocketgpsworld.com/menu_technical.php
My Emtac Bluetooth GPS receiver came with a utility called Crux View which also gives GPS info including speed, but I'm not sure if it'll work with the Medion kit. Downloadable at the bottom of the page - 'Crux View for Pocket PC'.
http://www.transplantcomputing.com/techsupport.html
PostPosted: Thu Nov 20, 2003 12:41 pm    Post subject: Reply with quote
Yes, Vito Navigator will, check the review (middle screen) 0.4km/h
http://www.pocketgpsworld.com/vitonavigator.php
Roy
PostPosted: Sat Nov 22, 2003 11:38 pm    Post subject: Reply with quote
Is there a program which is free which tells you your speed?
aero
PostPosted: Sun Nov 23, 2003 1:39 am    Post subject: Reply with quote
Crux View does, and it's free, but we need a Pocket PC guru to tell us whether it'll work with GPS receivers other than the Emtac wireless one.
I provided a link to it in my first post.
Smile
PostPosted: Sun Nov 23, 2003 10:20 am    Post subject: Reply with quote
There are a few freeware GPS Info Utilities that will report speed but none will work in conjunction with your navigation software, it's one or the other I'm afraid as only one application at a time can communicate with the GPS COM Port.
Roy
PostPosted: Sun Nov 23, 2003 11:32 am    Post subject: Reply with quote
yeah that would be fine. Only want to see what the speed works out like.
I downloaded that but had troble getting it working[/list]
PostPosted: Sun Nov 23, 2003 11:53 am    Post subject: Reply with quote
Try TomToms GPS Info Application. Get it at http://www.tomtom.com/support/ce/downloads/ppcgps207.zip
You'll need to configure the Medion GPS as 'NMEA 0183v2 4800' on 'COM1'
On the Status Tab if you have configured it correctly you will see a line of dots moving from left to right between the GPS and PDA Icons. Once a lock is acquired you will have Lat/Lon and Speed Readouts, you can switch between Km/H, MPH or even Kts! on the GPS tab.
pronto
PostPosted: Mon Nov 24, 2003 6:56 pm    Post subject: Reply with quote
Tried that on my Aldi/Medion setup and it works perfectly. Reads about
3mph below the speedo - so I guess the speedo is reading high. Don't know what he accuracy of GPS is at about 30mph tho'?
Mike
PostPosted: Mon Nov 24, 2003 7:02 pm    Post subject: Reply with quote
Given a constant speed on level ground the GPS is as near accurate as you will get in a consumer device. Uneven acceleration or rapid changes in altitude will affect the accuracy.
If you drive at an indicated 30mph on the GPS then you will be as near to excatly 30mph as possible, of course using the speedo at least gives you a margin of error should you encounter our boys in blue or a safety camera one day Thumbs Up
peeved
PostPosted: Tue Dec 16, 2003 6:38 pm    Post subject: Reply with quote
I have downloaded this application and it works as stated on my Medion, there is one question I would like to ask, what does the blue arrow shown top right point to?
PostPosted: Tue Dec 16, 2003 7:04 pm    Post subject: Reply with quote
That is your direction of travel in relation to North with your bearing in degrees below that. So if you are heading due East the arrow would point to 3 'O' Clock and the heading would 90 degrees.
peeved
PostPosted: Thu Dec 18, 2003 9:59 am    Post subject: Reply with quote
Ah! Thank you very much, all is now clear!
Paul
dejongj
PostPosted: Tue Dec 23, 2003 11:11 am    Post subject: Reply with quote
Depending the car you have, it is quite easy to recalibrate. My 15 year old BMW has got the function on the board computer to 'correct' the speedo if you fit inappropriate tyres. Might be worth checking out as it is a lot safer to use your speedo to check the speed than a PDA.
22.062 (12 Jun 24)
