Pocket GPS World :: View topic - RoadAngel with TomTom
PaulT
PostPosted: Sat Nov 15, 2003 1:53 am    Post subject: RoadAngel with TomTom Reply with quote
Is it possible to buy the Road Angel GPS Speed Camera Detection unit with Tom Tom software on an IPAQ 3870 Question
If so, where would I be able to purchase a connecting cable and would I need anything else Question
Pc-Mobile
PostPosted: Sat Nov 15, 2003 9:05 am    Post subject: Re: RoadAngel with TomTom Reply with quote
You just need a serial interface for your PPC.
See: http://pc-mobile.net/pdaserial.htm
You also need an extension serial cable which is available from most PC accessories shop.
Pc-Mobile
http://pc-mobile.net/gps.htm
Talkingbollox
PostPosted: Sat Nov 15, 2003 11:57 am    Post subject: Reply with quote
The Road Angel has a Holux GPS engine and you can purchase a cable set from http://www.holux-uk.com/Products/RoadAngel/adapters.htm[/url]
PaulT
PostPosted: Sat Nov 15, 2003 12:31 pm    Post subject: Reply with quote
I read somewhere that you won't get two apps talking to the same GPS Receiver.
Will Road Angel & Tom Tom operate simultaneously without problems
Thanks for the quick replies so far Smile
PostPosted: Sat Nov 15, 2003 1:24 pm    Post subject: Reply with quote
Yes the Road Angel will because basically what is is doing is taking the GPS feed, and creaeting a duplicate of it then sending it out to the Serial port on the back of the Road Angel, so you will be able to use both at the same time without fail.
The only thing with the Road Angel is that it doesn't output GPGSA and GPGSV which means you won't see any sat bars in TomTom or other apps, but it will still work and give you navigation, you just won't be able to see the satellite strengths.
PaulT
PostPosted: Sat Nov 15, 2003 2:03 pm    Post subject: Reply with quote
Last Questions
Is the Origin b2 much better than the Spped Angel ?
Is there a retailer who would supply and fit all the required kit - hardwired in car electrics rather than cigarette lighter ?
Talkingbollox
PostPosted: Sat Nov 15, 2003 5:20 pm    Post subject: Reply with quote
Actually you can see the number of satellites in view and in TT2 on the map and navigator screens. You just don't see the grey/red bars and the 2D/3D fixe info on the GPS status screen.
PostPosted: Sat Nov 15, 2003 8:18 pm    Post subject: Reply with quote
Exactly, this is the GPGSA and GPGSV data that's missing from the NMEA stream.
darrenkite
PostPosted: Fri Nov 28, 2003 8:28 pm    Post subject: Help! Reply with quote
Need a bit of help on this...
Have an Ipaq 3660 with a serial cable going to my Road Angel. Have got the GPS output on the Road Angel yet doesn't seem to work on TomTom..
Do you know what settings I have to set the GPS on the Ipaq to, to work with Road Angel? Do I have to setup the serial connection?
Based on the info before do i understand that entering the GPS section and looking at the status will not show my long&lat fix but if i looked in setting a route on TomTom then it would work?
If anyone can help from the beginning of setting it all up, it'd be much appreciated.
Talkingbollox
PostPosted: Fri Nov 28, 2003 9:09 pm    Post subject: Reply with quote
First of all where did you get the cable set? Does it have built in denull? If the cable is ok do you have a newish Raod Angel? If so it outputs NMEA @ 4800. The older verson with the older firmware outputs at 9600.
In the GPS utility, go to the GPS tab and uncheck the top left box, set the top option to NMEA 0183v2 4800 or 9600, and the second option to Serial Cable on COM1, then check the left box.
Hope this works!
darrenkite
PostPosted: Fri Nov 28, 2003 9:58 pm    Post subject: Reply with quote
Cheers....
Well to start off with it's a brand new Road Angel....
Then basically I got a serial sync cable and found it had the wrong end on it so then further bought a M/M 9 way serial cable so it would connect to the Road angel - guess this may be where it's gone wrong?
Seen mention of having to set-up the serial connection in "connections" and setting it to a Hayes compatible on COM1???!!!???!
Or maybe I just need to get the proper 1 cable?
Talkingbollox
PostPosted: Fri Nov 28, 2003 11:04 pm    Post subject: Reply with quote
Sounds like the cable - you need one of these http://www.expansys.com/product.asp?code=NM-D9F-D9M to feed out of the RA or you could get a "proper" cable set from Holux UK wihich also charges the ipaq at the same time....
22.105 (30 Oct 24)
