Pocket GPS World :: View topic - i3 mounts
i3 mounts
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Mr_Gonzales
PostPosted: Sun Feb 26, 2006 10:21 pm    Post subject: Reply with quote
PM me and I'll pass on the details, depending on whether you want to pay by cheque or paypal.
Andy
Marty-Party
PostPosted: Fri Apr 07, 2006 9:03 pm    Post subject: Reply with quote
As an update for anyone wanting an alternative mount for their i3, I have used the 17mm balls from Mr Gonzales together with a Brodit Pro-Clip for my Saab 9-5. It works just great.
I have drilled through the Pro-Clip and used a 6mm by 25mm screw, washer and nut. The 17mm ball screws onto the end so the i3 sits about 15mm proud of the Pro-Clip. This seems to be about the right height allowing easy positioning (can be seen from passenger seat if required). It also allows the i3 to be easily removed by angling all the to the maximum travel and it just pops off. A very neat soluion.
I will try and post some pics later.
Total cost £5 for 2 x balls (I have a spare), £15.99 fro the Pro-Clip and a few pence for the screws.
ben_e71
PostPosted: Sat Apr 08, 2006 7:55 am    Post subject: Reply with quote
I have also managed to make one very similar for my Mark 2 MX5. Used the balls from Mr G (nice work fella :D ) a dashmount bracket and a found a screw from a kids climbing frame the worked (TP tys i think --- Rolling Eyes okay it was all I had that worked) and then used some nylon lock nuts to provide a secure fix up screw to ball joint - - so go on give it a try
matb
PostPosted: Fri Apr 21, 2006 2:03 am    Post subject: Reply with quote
mr gonzales and marty party
i have sent you both pm regarding a mount.
mr g please will you make me one, if not marty party do you still have a spare ?
bumpkin
PostPosted: Fri Apr 21, 2006 11:25 am    Post subject: Reply with quote
I've been waiting for a reply from Mr_Gonzales for a few days now, seems that he's not about that much. Maybe he's too busy making mounts? Having purchased Ram mount kit for my bike I now need him to make a Ram ball to i3 ball adaptor, I'll a little stuck if he's disappeared Crying or Very sad
I went for the Ram option as it's quickly detachable leaving nothing sticking out and offers a good range of adjustability to cater for my expanding tank bag whilst not obscuring the instruments too much.
Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10
Marty-Party
PostPosted: Fri Apr 21, 2006 1:00 pm    Post subject: Reply with quote
Sent you another PM
Marty-Party
PostPosted: Fri Apr 21, 2006 1:04 pm    Post subject: Reply with quote
I don't know the whereabouts of Mr G but don't forget it has been Easter. Maybe he has been away?
Mr_Gonzales
PostPosted: Fri Apr 21, 2006 2:31 pm    Post subject: Reply with quote
Yep, just been away over easter. Think I've contacted everyone now about mounts and so on - if I've missed anyone drop me another PM and I'll get back to you! These plastic balls are provong to be one of the most popular mounts!
Dilcymro
PostPosted: Tue Apr 25, 2006 2:20 pm    Post subject: Reply with quote
Hi all, Regarding mr gonzale`s balls I have ordered two off him and want to get some bolts whilst I am at the shops after. I take it the size I need to get is 6mm x whatever length I need, can someone confirm this before I go if possible. Just like to have everything ready for when I get them.
Thanks in advance....Dilwyn
Garmin Nuvi 2415
Where there`s a Dil ---- There`s a way
Kolster
PostPosted: Tue Apr 25, 2006 2:50 pm    Post subject: Reply with quote
Received my ball from Mr Gonzales yesterday, excellent item, very well made and it takes a standard M6 screw.
John.
Dilcymro
PostPosted: Tue Apr 25, 2006 2:56 pm    Post subject: Reply with quote
Thanks for the quick reply John, I was just going out.
Thanks again...Dilwyn
Garmin Nuvi 2415
matb
PostPosted: Tue Apr 25, 2006 5:23 pm    Post subject: Reply with quote
dilwyn, you did it again !!!!
i guess i shall have to get up earlier to post an item before you.
i have wiped the sweat off my brow as i have already manufactured my mount ready for mr.g's balls Laughing using an m6 x 50mm bolt fastened to a fixed airvent, then casually beaten with a large hammer until approx 40 degrees.
i wait with excitment Jumping With Joy
Dilcymro
PostPosted: Tue Apr 25, 2006 6:38 pm    Post subject: Reply with quote
Sorry Matb, we must be on the same wavelength, got some nuts and bolts while we were out, have you noticed you cant have one of anything anymore , you have to buy a whole packet of ten or twenty.
I have ordered one of these from ebay, bit pricey but we will see what it is like when it comes. The idea is to fit the bolt / ball onto this and then it will be quite neat and easily viewable for me and my navigator aka the wife. See what you think.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=7967127218&ssPageName=ADME:B:EOIBSA:UK:31ts
I hope I have done that right.
I might get everything for the weekend when I am off, so I can sort it out then.
Regards....Dilwyn
matb
PostPosted: Tue Apr 25, 2006 6:50 pm    Post subject: Reply with quote
makes my 12p bolt, washer and nut seem a little inadequate.
i went to the local ironmonger/ chippy where you can still buy in singles. only had a tenner on me so he gave me the bolt etc, with a promise i would come back to the shop in the future, and buy something else for 12p above asking price.
ah the good 'ol days
Dilcymro
PostPosted: Tue Apr 25, 2006 7:07 pm    Post subject: Reply with quote
Your showing your age again mat, no doubt if I had waited till we went somewhere decent I would have found a proper ironmongers, they wont go to waste anyway. I thought with this setup I can run the cables into the glove compartment and then just feed the amount I need through to the i3, make a hole in it to fit the bolt with mr gonzales`s ball on it and a small hole for the cables to run through and attach them to the i3.
We shall see anyway.
Regards....Dilwyn
Garmin Nuvi 2415
Page 3 of 8
