Pocket GPS World :: View topic - Ash10's Speed Camera Editing / Loading Software
Goto page Previous  1, 2, 3, 4, 5 ... 15, 16, 17  Next
Spenk
PostPosted: Thu Mar 23, 2006 5:34 pm    Post subject: Reply with quote
Thanks Ash10 Not Worthy - it doesn't like the fact that the files are in a sub directory in the original Zip file. Once I'd unzipped them and re-zipped them back into a stand-alone file it all worked great. Can't wait to try it out now to see how it all works!
Stamford_1
PostPosted: Thu Mar 23, 2006 8:44 pm    Post subject: Reply with quote
Thanks to Ash10 and MaFt I am now up and running.
Will try out tomorrow and let you know how it goes.
Kevin
Almahadeus
PostPosted: Thu Mar 23, 2006 8:49 pm    Post subject: Reply with quote
MaFt, can this post go to become a sticky as well? it is attracting loads of veiwing as well.
FirebladeDreamer
PostPosted: Thu Mar 23, 2006 10:11 pm    Post subject: Reply with quote
Very good Ash. It did have one hiccup though.
I'd deleted the dir that was the last one that the loader had used. It noted this and said that a default was being used. It was telling me the dir it was using but as the window wasn't wide enough and you dont have word wrap on I couldn't see where it was.
Moving on to dropping the zip file. It came up with an error about not being
able to copy a bmp file. However repeating the drop a second time all was well. I'm sure you could repeat this by deleting the last used dir.
To help in this beta phase it might be handy if you could select the text in the log for copy and paste in which case I would have been able to give you a complete log.
Lastly It says checkout www.garminpoi.co.uk for the latest version. Is that really what you mean.
The above aside its great. Let me know if you want more info on the above.
Ash10
PostPosted: Thu Mar 23, 2006 11:31 pm    Post subject: Reply with quote
FirebladeDreamer wrote:
Moving on to dropping the zip file. It came up with an error about not being able to copy a bmp file. However repeating the drop a second time all was well. I'm sure you could repeat this by deleting the last used dir.
Thanks for that - duly noted ;)
What's happening is that it's trying to save the first bitmap to the non-existant directory, which fails.
Then it unzips the first database file to that directory, which doesn't fail because the unzip routine creates the directory if it doesn't already exist.
All further operations are unaffected, because the directory has now been created 8)
ben_e71
PostPosted: Sun Mar 26, 2006 12:04 am    Post subject: Reply with quote
:D :D :D :D Laughing Laughing Laughing :D :D :D :D
can i just say good work fellas and thanks you very much.....
just one small point can it be used with the speed zone file so that the icon has the speed on it?
thanks
2carkev
PostPosted: Sun Mar 26, 2006 9:13 pm    Post subject: Reply with quote
Absolutely excellent Idea Idea ash, thank you :D
shedracer
PostPosted: Tue Mar 28, 2006 6:16 pm    Post subject: Reply with quote
Hi, I`m new to this forum and have been trying to convert the zip file so the camera warnings come on irrespective of what speed I`m doing for my i3. I am using the latest Pocket GPS World POI`s and the Garmin POI loader that I downloaded from here as well. The problem I am having is that when I drag and drop the Zipped file to the app, it says "error". I have deleted both downloads and re downloaded them, and still I am getting an error.
Please help. Embarassed
zogman
PostPosted: Tue Mar 28, 2006 6:22 pm    Post subject: Reply with quote
you need to open the zip file first then drag and drop..
707
PostPosted: Wed Mar 29, 2006 11:05 am    Post subject: Reply with quote
Look, I'm not normally this thick Wink, but I cannot get this to work either.
I drag the zipped file into the app. and it says errors.
In the unzipped POI folder all I get is 5 x .bmp files and 2 x .gpx files (the Red light & Temp ones) scrolling up the log I see "Failed to unzip" & "failed to open"
I've been using the other camera app for a while now and just thought I'd give this a go, but now I'm stuck Confused
Any ideas
Colin
shedracer
PostPosted: Wed Mar 29, 2006 11:14 am    Post subject: Reply with quote
I tried that as well, still no luck. Sad When i dragged and dropped the zipped file into the app, it processed it but said there was an Error. When I dragged and dropped the unzipped file into the app, there was no apparent process!
I really want it to work, but so far I haven't been successful. Sad Crying or Very sad
Ash10
PostPosted: Wed Mar 29, 2006 1:42 pm    Post subject: Reply with quote
What are are actual errors? Have a look in the report log a few lines up...
Ash10
PostPosted: Wed Mar 29, 2006 1:46 pm    Post subject: Reply with quote
Sounds like your using the "Speed zoned" version of the database, you want the "POI Loader" version...
707
PostPosted: Wed Mar 29, 2006 1:58 pm    Post subject: Reply with quote
Embarassed Embarassed Embarassed Embarassed Embarassed
oops that did it Laughing
Thanks Ash
Colin
shedracer
PostPosted: Wed Mar 29, 2006 6:00 pm    Post subject: Reply with quote
same here, now sorted. Will try it out on my way to work tonight.
Cheers Ash Thumbs Up
Page 4 of 17
22.055 (29 May 24)
