Pocket GPS World :: View topic - Unable to do full post code search
FriendlyBloke
PostPosted: Thu Mar 02, 2006 4:48 pm    Post subject: Unable to do full post code search Reply with quote
Have just received a replacement Garmin i3 and currently doing all the checks. On my old i3 I coud do a full post code search prior to being prompted for house number. On my new one I get as far as entering the first part, and then it brings up all the options but still not in a full format.
So for eg. to search for AB12 3CD, I enter AB12 and it comes up with the full list of AB12 1, AB12 2, AB12 3......................etc. Is this a fault, or normal. Like i said, this didn't happen on my old one.
Please help
FB
Almahadeus
PostPosted: Thu Mar 02, 2006 4:54 pm    Post subject: Reply with quote
Make sure you have the up-to-date firmware installed first.
PostPosted: Thu Mar 02, 2006 5:12 pm    Post subject: Reply with quote
some area's don't have the full postcode... try 'bd13 3qx' as i know that works
FriendlyBloke
PostPosted: Thu Mar 02, 2006 5:17 pm    Post subject: Reply with quote
Thanks for the responses
Haven't updated firmware yet, but will this really make a difference?
Tried Bd13 3qx and same happend. As soon as I get to Bd13 3 it doesn't allow me to enter the full code??? Very confused?
FB
PaulB2005
PostPosted: Thu Mar 02, 2006 5:18 pm    Post subject: Reply with quote
Not sure what you mean by this. Once i've entered AB12 it lists AB12 1, AB12 2 etc. Just enter a space and keep typing the rest of the address. Works fine.
FriendlyBloke
PostPosted: Thu Mar 02, 2006 5:20 pm    Post subject: Reply with quote
No it doesn't I'm afraid...................i'll see what the updated firmware does, but I think its faulty.
mhb
PostPosted: Thu Mar 02, 2006 5:29 pm    Post subject: Reply with quote
Mine (V8 maps 2.7 f/w) allows me to enter a full postcode before asking for a house number.
I just tried it again and MaFt's postcode worked as it should and found an address and your own example postcode worked but obviously couldn't be found as I assume it doesn't exist.
FriendlyBloke
PostPosted: Thu Mar 02, 2006 5:32 pm    Post subject: Reply with quote
Thanks again for responses.
Put another way, the i3 will not allow me to enter a full postcode, its almost like it doesn't have a record of any postcodes after the 1st digit on the second half of the code - useless..............
PostPosted: Thu Mar 02, 2006 5:42 pm    Post subject: Reply with quote
yeah, i think you have a duff unit there... or something funny happening! usually when you're typing in a postcode it will shorten the list in the background but let you keep on typing it...
mhb
PostPosted: Thu Mar 02, 2006 5:44 pm    Post subject: Reply with quote
It sounds like it is malfunctioning. Tried a reset yet?
Lester_Burnham
PostPosted: Thu Mar 02, 2006 5:51 pm    Post subject: Reply with quote
What version of firmware are you running?
FriendlyBloke
PostPosted: Thu Mar 02, 2006 5:54 pm    Post subject: Reply with quote
.......software version 2.10
Lester_Burnham
PostPosted: Thu Mar 02, 2006 6:08 pm    Post subject: Reply with quote
I'm pretty sure that's your problem.
Can't remember the exact point it came in (haven't got the change log to hand) but I'm sure full postcode searches came in with a certain firmware level.
Most seem to run 2.70, some are on 2.50 or 2.60.
I'd say anything above 2.50 is stable - from what I read. And I've got no reason to think you should have a problem with 2.70.
PostPosted: Thu Mar 02, 2006 6:51 pm    Post subject: Reply with quote
mine when it was new (bought in september last year on the official release date) came with version 2.3... try updating to latest 2.7 and see if that helps
FriendlyBloke
PostPosted: Thu Mar 02, 2006 8:32 pm    Post subject: Reply with quote
As ever, premature moaning and whinging from me - u were all right, updated to 2.7 and i3 is working properly. I must have also had 2.3 when i first bought in september because i never had the postcode problem. I can't believe Garmin would have sold the i3 with that software on it???
Thanks to all for your help
FB
