Posted: Thu Feb 23, 2006 2:44 pm Post subject: File needed
Hello all,
I have the Acer N35 running Destinator 3. I was wondering if someone could possibly send me the "circle" voice file for roundabouts! I have installed a different file which I dont like as much and I didnt keep a copy of the original!
Also, the original file that I require tells me I am 3 miles from the roundabout when I am only 2 miles from it, any idea if this can be changed when I, hopefully, receive the file from one?
pm me your email and i'll send you the file you want. Alternatively you can reinstall destinator. Have you changed anything in the maneuver file which may be causing it to say three instead of 2. It should be set for 3km or 2 miles dependant on which units you want to use. Was it working before with 2 miles? _________________ Goodmans GNAV10
WinCE 4.20(0)
OEM: Centrality Communication Inc
Destinator OP v 5.1.174
Must be something wrong on your DestinaorVoiceManeuver.inf in the All folder. Copy it and paste it on a reply so we can see what is wrong.
You are sure it is saying 3 miles and not 3 kilometers? If it is saying kilometers then it is just a simple case of changing your general settings to miles and yards instead of meters and kilometers. _________________ Goodmans GNAV10
WinCE 4.20(0)
// All the fields must be placed in one line. The fields will divided by commas.
// Fields description:
// 1) ::MC The maneuver command is a key word.
// 2) A command is being built from two parts (each part is a key word). The two
// parts will be divided by a ‘*’ sign. The first part will describe the maneuver name
// (TURN_LEFT for example) and the second part will describe the distance
// (THIRD_DISTANCE for example).
// 3) For future use, (‘0’ will be entered).
// 4) to N) The words from which the sentence is built. Each word (or words) between two
// commas must refer to a wav files with the same name which exists in the same
// folder as the information file, (if a file or a command for that matter will not be
// found silent mode will be activated).
// The max value of ‘N’ will be ‘13’, (will allow a ten words sentence).
// N+1) The maneuver textual description, (will be written between quotation marks -
// commas are possible).
// FIRST_DISTANCE - three kilometers / two miles.
// SECOND_DISTANCE - five hundred yards/meters.
// THIRD_DISTANCE - two hundred yards/meters.
// FOURTH_DISTANCE - thirty meters, no distance will be specified.
::MC,TURN_LEFT*FIRST_DISTANCE,0,0,t_l;3*2;UNITS,"Left turn 3/2 miles / three kilometers"
::MC,TURN_LEFT*SECOND_DISTANCE,0,0,t_l;500;UNITS,"Left turn five hundred yards/meters"
::MC,TURN_LEFT*THIRD_DISTANCE,0,0,t_l;200;UNITS,"Left turn two hundred yards/meters"
::MC,TURN_LEFT*FOURTH_DISTANCE,0,0,t_l,"Turn left"
::MC,TURN_RIGHT*FIRST_DISTANCE,0,0,t_r;3*2;UNITS,"Right turn 3/2 miles/kilometers"
::MC,TURN_RIGHT*SECOND_DISTANCE,0,0,t_r;500;UNITS,"Right turn five hundred yards/meters"
::MC,TURN_RIGHT*THIRD_DISTANCE,0,0,t_r;200;UNITS,"Right turn two hundred yards/meters"
::MC,TURN_RIGHT*FOURTH_DISTANCE,0,0,t_r,"Turn right"
::MC,KEEP_LEFT*FIRST_DISTANCE,0,0,k_l;3*2;UNITS,"Keep left 3/2 miles/kilometers"
::MC,KEEP_LEFT*SECOND_DISTANCE,0,0,k_l;500;UNITS,"Keep left five hundred yards/meters"
::MC,KEEP_LEFT*THIRD_DISTANCE,0,0,k_l;200;UNITS,"Keep left two hundred yards/meters"
::MC,KEEP_LEFT*FOURTH_DISTANCE,0,0,k_l,"Keep left"
::MC,KEEP_RIGHT*FIRST_DISTANCE,0,0,k_r;3*2;UNITS,"Keep right 3/2 miles/kilometers"
::MC,KEEP_RIGHT*SECOND_DISTANCE,0,0,k_r;500;UNITS,"Keep right five hundred yards/meters"
::MC,KEEP_RIGHT*THIRD_DISTANCE,0,0,k_r;200;UNITS,"Keep right two hundred yards/meters"
::MC,KEEP_RIGHT*FOURTH_DISTANCE,0,0,k_r,"Keep right"
::MC,EXIT_LEFT*FIRST_DISTANCE,0,0,e_l;3*2;UNITS,"Keep left 3/2 miles/kilometers"
::MC,EXIT_LEFT*SECOND_DISTANCE,0,0,e_l;500;UNITS,"Keep left five hundred yards/meters"
::MC,EXIT_LEFT*THIRD_DISTANCE,0,0,e_l;200;UNITS,"Keep left two hundred yards/meters"
::MC,EXIT_LEFT*FOURTH_DISTANCE,0,0,e_l,"Keep left"
::MC,EXIT_RIGHT*FIRST_DISTANCE,0,0,e_r;3*2;UNITS,"Keep right 3/2 miles/kilometers"
::MC,EXIT_RIGHT*SECOND_DISTANCE,0,0,e_r;500;UNITS,"Keep right five hundred yards/meters"
::MC,EXIT_RIGHT*THIRD_DISTANCE,0,0,e_r;200;UNITS,"Keep right two hundred yards/meters"
::MC,EXIT_RIGHT*FOURTH_DISTANCE,0,0,e_r,"Keep right"
::MC,U_TURN*FIRST_DISTANCE,0,0,u_t;3*2;UNITS,"U turn three 3/2 miles/kilometers"
::MC,U_TURN*SECOND_DISTANCE,0,0,u_t;500;UNITS,"U turn five hundred yards/meters"
::MC,U_TURN*THIRD_DISTANCE,0,0,u_t;200;UNITS,"U turn two hundred yards/meters"
::MC,U_TURN*FOURTH_DISTANCE,0,0,u_t,"U turn"
::MC,ROUND_ABOUT*FIRST_DISTANCE,0,0,circle;EXIT_NUMBER;exit;3*2;UNITS,"Take round about xxxx exit 3/2 miles/kilometers"
::MC,ROUND_ABOUT*SECOND_DISTANCE,0,0,circle;EXIT_NUMBER;exit;500;UNITS,"Take round about xxxx exit five hundred yards/meters"
::MC,ROUND_ABOUT*THIRD_DISTANCE,0,0,circle;EXIT_NUMBER;exit;200;UNITS,"Take round about xxxx exit two hundred yards/meters"
::MC,ROUND_ABOUT*FOURTH_DISTANCE,0,0,circle;EXIT_NUMBER;exit,"Take round about xxxx exit"
::MC,DESTINATION*FIRST_DISTANCE,0,0,app_destination;3*2;UNITS,"Approacing destination in 3/2 miles/kilometers"
::MC,DESTINATION*SECOND_DISTANCE,0,0,app_destination;500;UNITS,"Approacing destination in five hundred yards/meters"
::MC,DESTINATION*THIRD_DISTANCE,0,0,app_destination;200;UNITS,"Approacing destination in two hundred yards/meters"
::MC,DESTINATION*FOURTH_DISTANCE,0,0,destination,"You Have Arrived"
// 1) ::MW The multiple word command is a key word.
// parts will be divided by a ‘*’ sign. The first part will describe the command name
// RED_LIGHT_CAMERA for example) and the second part will describe the distance type
// DISTANCE_TYPE_800 for example).
// 4) For future use, (‘0’ will be entered).
// 5) to N) The words from which the sentence is built. Each word (or words) between two
// N+1) The command textual description, (will be written between quotation marks -
::MW,POI_ALERT_1*DISTANCE_TYPE_1000,0,0,141,1000;;UNITS,"Speed Camera Alert"
::MW,POI_ALERT_1*DISTANCE_TYPE_800,0,0,141,800;UNITS,"Speed Camera Alert"
::MW,POI_ALERT_1*DISTANCE_TYPE_600,0,0,141,600;UNITS,"Speed Camera Alert"
::MW,POI_ALERT_1*DISTANCE_TYPE_400,0,0,141,400;UNITS,"Speed Camera Alert"
::MW,POI_ALERT_1*DISTANCE_TYPE_100,0,0,141,100;UNITS,"Speed Camera Alert"
::MW,POI_ALERT_1*DISTANCE_TYPE_50,0,0,141,50;UNITS,"Speed Camera Alert"
::MW,POI_ALERT_2*DISTANCE_TYPE_1000,0,0,142,1000;;UNITS,"Red Light Camera Alert"
::MW,POI_ALERT_2*DISTANCE_TYPE_800,0,0,142,800;UNITS,"Red Light Camera Alert"
::MW,POI_ALERT_2*DISTANCE_TYPE_600,0,0,142,600;UNITS,"Red Light Camera Alert"
::MW,POI_ALERT_2*DISTANCE_TYPE_400,0,0,142,400;UNITS,"Red Light Camera Alert"
::MW,POI_ALERT_2*DISTANCE_TYPE_100,0,0,142,100;UNITS,"Red Light Camera Alert"
::MW,POI_ALERT_2*DISTANCE_TYPE_50,0,0,142,50;UNITS,"Red Light Camera Alert"
// 1) ::SW The single word is a key word.
// 2) The single word definition.
// 4) The relevant single word. The word must refer to a wav file with the same name which exists
// in the same folder as the information file, (if a file or a needed word for that matter will not be
// 5) The maneuver textual description, (will be written between quotation marks -
// Spacify:
// 1) First maneuver followed by second maneuver, (1).
// 2) Second maneuver followed by first maneuver, (2).
// No distance will be specified.
::SW,FOLLOWED_BY,0,0,(1);followed_by,"...Followed by..."
// Will be described by the letters combination 'UNITS'.
::SW,METERS,0,0,meters,"meters"
::SW,KILOMETERS,0,0,kmeters,"kilometers"
::SW,YARDS,0,0,yards,"yards"
::SW,MILES,0,0,miles,"miles"
// Will be described by the letters combination 'EXIT_NUMBER'.
::SW,FIRST,0,0,first,"first"
::SW,SECOND,0,0,second,"second"
::SW,THIRD,0,0,third,"third"
::SW,FOURTH,0,0,fourth,"fourth"
::SW,FIFTH,0,0,fifth,"fifth"
::SW,SIXTH,0,0,sixth,"sixth"
::SW,SEVENTH,0,0,seventh,"seventh"
::SW,EIGHTH,0,0,eighth,"eighth"
::SW,NINTH,0,0,ninth,"ninth"
::SW,TENTH,0,0,tenth,"tenth"
::SW,TURN_LEFT,0,0,t_l,"Turn left"
::SW,TURN_RIGHT,0,0,t_r,"Turn right"
::SW,KEEP_LEFT,0,0,k_l,"Keep left"
::SW,KEEP_RIGHT,0,0,k_r,"Keep right"
::SW,EXIT_LEFT,0,0,e_l,"Exit to the left"
::SW,EXIT_RIGHT,0,0,e_r,"Exit to the right"
::SW,U_TURN,0,0,u_t,"U turn"
::SW,ROUND_ABOUT,0,0,circle,"round about"
::SW,YOU_ARE_OVER_THE_SPEED_LIMIT,0,0,yaotsl,"You are over the speed limit"
::SW,ROUTE_RECALCULATION,0,0,yhltcr,"Route recalculation"
::SW,GPS_SIGNAL_TOO_LOW,0,0,signallow,"GPS signal too low"
::SW,GPS_NOT_FOUND,0,0,gpsnotfound,"GPS not found"
::SW,START_NAVIGATION,0,0,startnavigation,"Start navigation"
::SW,REACHED_DESTINATION,0,0,destination,"You have arrived to your destination"
::SW,TMC_MESSAGE_RECIEVED,0,0,132,"TMC Alert"
On first look I can't see a problem with that, just to recap, you didn't answer my question:
WinCE 4.20(0)
Not sure why your device is playing up with the distances.
There was a problem with the initial ini file, but as your working from the edited file this should work ok.
Are you sure you have replaced the voicemanuvers file since the hard reset as the hard reset will replace the file I sent you with the default file which has the bug your talking about.
Mikey _________________ Mikey
_______________________________________
Acer N35
Tomtom ver 6.010(7720)
Tomtom map UK & IE Plus v675
The '3 miles when its 2' issue is a known problem with D3 and is covered somewhere in the stickies above I believe. _________________ Tom Tom GO 720
Orange M3100, Orange SPV M5000
TomTom Navigator 6, Destinator 6
Holux GPSslim
