baza0078 Occasional Visitor
Joined: Feb 08, 2006 Posts: 27 Location: Watford Herts. UK.
Posted: Fri Feb 10, 2006 6:33 pm Post subject: |
Just done this, this afternoon 52pence for a mono female jack connector and it fits snug between the two locating lugs inside the case. I have set volume to 5 in the car but with earphone 1 or 2 is loud enough. Mind you with me loud pipes on my Harley I might need # 5 .
BaZa. |
ride4smilesjonny Regular Visitor
Posted: Fri Feb 10, 2006 6:55 pm Post subject: |
nice work baza......roll on the summer!!!!! - ever get to the lakes in cumbria? 8) _________________ **********************************
Hi ho - Hi ho its off to Arran i go,
with my i3 and a cup of tea hi ho, hi ho
hi ho hi ho.....
www.ride4smiles.co.uk
£3500 raised in two weeks! :-) |
Posted: Fri Feb 10, 2006 9:20 pm Post subject: |
Nice, im over there plenty in the summer, im around an hour away from my place, so its a real nice ride over. looking forward to using the i3 to find hidden nooks and crannys ive spotted on google earth then entered into system as poi. - _________________ **********************************
hi ho hi ho.....
JackTheKipper Occasional Visitor
Posted: Mon Feb 13, 2006 10:11 pm Post subject: |
First off, hello to all - Excellent source of info this is & it's helped me make my mind up as to what system to get (on a shoestring budget that is) for my bike.
As my electrical skills are about as much use as an ashtray on my Bandit , could someone plz do a step-by-step guide for installing a headphone jack to an i3 (I will be getting a more proficient m8 to do the required soldering of course!) |
Posted: Mon Feb 13, 2006 10:46 pm Post subject: |
JackTheKipper wrote: |
Welcome Jack, tools needed, T6 torx driver, (to open unit), soldering iron, solder, drill(to enable plug cable to be fed through the rear), jack plug (female).
open unit, open a beer
gently prise gubbings from rear of casing
drill hole in back of unit (see my pic) - drink beer
locate internal speaker - drink beer
pass cable from plug through hole you just drilled - drink beer
solder the two leads from female plug socket (one to each of the wires on the internal speaker)
put all back together
drink more beer!
DO NOT RIDE UNTIL SOBER!! 8O _________________ **********************************
hi ho hi ho.....
Skippy Pocket GPS Verifier
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Tue Feb 14, 2006 2:08 am Post subject: |
ride4smilesjonny wrote: | DO NOT RIDE UNTIL SOBER!! |
And don't run while carrying the screwdriver either. _________________ Gone fishing! |
Posted: Tue Feb 14, 2006 10:39 am Post subject: |
cheers me dears - at last an excuse to drink (as if I needed one!)
One last question before I lay siege to my new i3 - what exactly am I asking for at my local maplins re. female jack, cable etc (I would like them to think I know what I'm doing !) |
Posted: Tue Feb 14, 2006 1:19 pm Post subject: |
JackTheKipper wrote: | cheers me dears - at last an excuse to drink (as if I needed one!)
Just ask at Maplins for a Mono female jack connector for an earphone.
52 pence in the Watford store.
You can do it two ways as said in previous post have a wire hanging out the rear with the connector on or my way actually fitting the female to the case like in a walkman/ipod etc.
When your mate opens the front cover off place it to one side that's the screen (keep away from dust etc.)
Then gently prising the unit from the back you will then have a couple of inches to play with of wire that is soldered to the printed circuit and the speaker.
Looking into the back of the cover (that holds the speaker) you will see 4 locating points (female) drill in between the two nearest the original speaker, and you will find that the connector from Maplins fits in a treat and does not protrude on to any thing else.
Solder either side on the lugs (ie) 9 o'clock and 3 o'clock and onto either wire on speaker and replace.
I found that level 2 or 3 is only needed on the bike where in the car with radio etc I level it to 5. Mind you I wear an open face and it's a (tractor) Harley.... |
Posted: Tue Feb 14, 2006 6:26 pm Post subject: |
and never run with scissors either _________________ **********************************
hi ho hi ho.....
andybike Occasional Visitor
Joined: Oct 11, 2005 Posts: 26 Location: warwickshire uk
Posted: Thu Feb 16, 2006 9:31 am Post subject: |
Eagle747 wrote: | Yup - your picture works just fine. Most mini jacks can be wired to cut out tyhe main speaker too - which is what I plan to do. Now you've taken the plunge and done it (which shows there must be enough room inside I defo going to do it! All we need now is a waterproof jacket that still makes the screen readable. Freezer bags are bot that good for visibility! |
tried clingfilm?
keep some slack in the clingfilm so you can use the scroll wheel. |
Posted: Sat Feb 18, 2006 10:27 pm Post subject: |
At last my lickle i3 has arrived !!
VERY with a capital VERY pleased so far...managed to safely navigate myself round the north-face of my local shops (my kids were adamant that they already knew the way but i wasn't listening) & then it safely took my missus to the local shopping mall (worse luck!!)
Like a kid at chrimbo I then attached my extremely yummy mount (care of monsieur gonzales - mucho gracias) to my Bandit & stood back & admired my new set-up :D
Now to take the plunge & get it wired for sound ie. headphones.
Call me Mr. Thicky if you want but could I please have a shopping list of exactly everything I need to get the job done ie. scredrivers, wires, jacks etc (please bear in mind that I already have the beer! ) |
Posted: Sat Feb 18, 2006 11:30 pm Post subject: |
JackTheKipper wrote: | (please bear in mind that I already have the beer! ) |
ME too, ill let you know in the morning, or read this thingyeralier on!
ta! _________________ **********************************
hi ho hi ho.....
Posted: Sun Feb 19, 2006 12:16 am Post subject: |
ok, here goes,
a T6 Torx driver (to open unit)
a female jack connector, eithe like picture above or a wired one like mine,
bought a blister pack in maplin for bout a fiver, which included female connector and a curly extender lead!! - bargain)
Another female connector to wire into a flat ear piece inside lid
BEER
solder
solder iron
a loose cable tie
theory:-
open unit,
locate internal speaker,
drill hole in rear of i3 (4mm ish)
pass cable from female plug (if chosen cable version) through drilled hole
solder female jack connector to internal speaker (tag for tag)
put unit back together
plug in curly extension lead to unit and lid,
TA-DAAA!!!
(remember, some female jack plugs have a 3 way possible connector, not just two, make sure you marry these up true!)
drink beer, but not for me, had enuf tonite
BED now
any probs pm me!
night all!
j _________________ **********************************
hi ho hi ho.....
Posted: Sun Feb 19, 2006 1:44 pm Post subject: |
No more sherberts for me _________________ **********************************
hi ho hi ho.....
