Pocket GPS World :: View topic - Lost speed camera's
Lost speed camera's
pogbellies
PostPosted: Sat Jan 28, 2006 6:18 pm    Post subject: Lost speed camera's Reply with quote
Have reposted here as nobody seems to be looking in the Checkpoint forum!
For about a week I had everything working fine.
Now TT5.21 doesn't display speed camera's. Everything else is there from Halfords to McDonalds! but not the speed camera's. The overlays are all there as are the bmp's in my GB map folder on the SD card but they still don't show up.
Any ideas[/b]
PostPosted: Sat Jan 28, 2006 7:21 pm    Post subject: Reply with quote
How many POI's have you got enabled? there is a limit of 39 so if you have hit that by enabling all the other ones it will not display the safety camera POI's, try turning off the others and see if you can re-select the cameras - Mike
pogbellies
PostPosted: Sun Jan 29, 2006 1:01 am    Post subject: Reply with quote
I have 3 maps on my SD card, does the 39 include all the POI's enabled on every map or just the active map?
pogbellies
PostPosted: Sun Jan 29, 2006 1:10 am    Post subject: Reply with quote
More info;
I wondered if this was the problem, however Tom Tom is not even showing the speed cameras in the POI list to display which makes me think that the overlay is missing or corrupt, I have manually downloaded the latest speedcam overlays and bmp's and put them in the UK folder and still nothing.
PostPosted: Sun Jan 29, 2006 10:00 am    Post subject: Reply with quote
The limit is 39 in each Map Folder. Have you any other POI Categories in the Map Folder?
The GB Safety Cameras will only show up in a Map that covers GB.
If you go into Manage POI > Add POI, how many Categories are displayed for selection?
pogbellies
PostPosted: Sun Jan 29, 2006 3:34 pm    Post subject: Reply with quote
There are 39 items listed in "Add POI" none of which are speed cameras.
There are 12 POI selected in "Enable/Disable POI" and speed cameras is not in the list as an option. There are a lot of other items in the list (banks, shops etc.) but I don't have most of them selected.
I am totally baffled by this I think I may remove the UK map from the SD card and reinstall it, then start again with the POI's.
Holux GPSmile60
Tom Tom Navigator 5.21
play.com 512mb SD
PostPosted: Sun Jan 29, 2006 3:46 pm    Post subject: Reply with quote
Try removing the POIs from the GB map folder (put them on to the PC, this is all files with .OV2 and its coresponding .BMP) then re-install the camera ones (if its speed zoned you should have 48 files in total to go on to the SD card 24 .OV2 and 24 .BMP, this leaves you with 15 more left to add in later if you want to) then try it again. I have seen exactly this when a mate downloaded and installed all sorts of POI's then couldn't get the cameras to go on. In the end I deleted the POI's and the cameras work - Mike
pogbellies
PostPosted: Sun Jan 29, 2006 5:26 pm    Post subject: Reply with quote
Thanks guys, that seems to have done the trick. Removed all POI's and replaced selectively.
Does this mean that synching Checkpoint from the PDA is a bad idea then, as doing so will surely mean that all the available POI's will be downloaded?
I only ask as its a lot quicker than downloading each overlay and bmp seperately.
Thanks again
Holux GPSmile60
play.com 512mb SD
PostPosted: Sun Jan 29, 2006 5:38 pm    Post subject: Reply with quote
I can't offer advice on this one as I only use TomTom's in built warning system, you can set it for double warnings by using both the single file and speed zoned and have spoken voice prompts per camera type etc.
Once you get used to the files you need from the PocketGPS database picking them out and transfering to the PDA takes less than 3 mins - (I did just this earlier today) - Mike
