Pocket GPS World :: View topic - Auto Night Mode
Auto Night Mode
Lunker
PostPosted: Fri Jan 20, 2006 12:50 am    Post subject: Auto Night Mode Reply with quote
I've got my Garmin i3 set to Auto in the night mode setting and I can't belive how acurate it is. 8O
How is it done and will it change with the different times of sun set and sun rise?
PaulB2005
PostPosted: Fri Jan 20, 2006 9:58 am    Post subject: Reply with quote
Sun Rise and Sun Set can be calculated if your position in the world is known. As the GPS system knows exactly where you are and what time it is, it can calculate when to switch mode. It will do it as the days lengthen and shorten with the same accuracy.
Ash10
PostPosted: Fri Jan 20, 2006 11:40 am    Post subject: Reply with quote
I found this thread:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=30906
using the Search function... ;)
alan_t
PostPosted: Fri Jan 20, 2006 7:11 pm    Post subject: Reply with quote
i've had the unit indoors connected to my usb port on my computer.
it auto switches to night mode on the evenings with out getting a gps signal.
maybe theres also a certain time it autoswitches.
Skippy
PostPosted: Fri Jan 20, 2006 11:01 pm    Post subject: Reply with quote
alan_t wrote:
it auto switches to night mode on the evenings with out getting a gps signal.maybe theres also a certain time it autoswitches.
Yes there is and it is based on your location. Some Garmin units will show the sunrise/set times in one of the data fields and you can see this changing if you are flying north or south in a plane. :D
If the GPS doesn't have a signal then it changes based on it's last known position. You can also switch the unit into indoors mode and change your position on some units and the sun rise/set times changes then too.
Gone fishing!
Lunker
PostPosted: Sat Jan 21, 2006 3:21 pm    Post subject: Reply with quote
Cool thanks guys :D
