dougconran Regular Visitor
Joined: Oct 07, 2004 Posts: 175 Location: Bury St Edmunds, Suffolk
Posted: Tue Jan 03, 2006 8:38 pm Post subject: Changed format of the PGPSW camera database |
PGPSW have changed the structure of the camera database for the i3, they have split out Gatsos and Mobiles into separate files for each speed with an associated icon showing the relevant speed.
Personally I think that is a retrograde step because I can't see the speed on the icon but I guess others will find it a benefit.
However - MaFt, can you remind me why it was that you re-named the camera files to zSpeed ... and is it something we should re-instate for the new files? (maybe it won't matter now ) |
andspenka Occasional Visitor
Joined: Sep 22, 2005 Posts: 24 Location: Co. Durham U.K.
Posted: Sat Jan 07, 2006 12:44 am Post subject: |
As far as I can remember it was just to put them to the bottom of the list, so when you're searching your custom points you don't get a load of cameras in the middle of your other POI's. _________________ Andspenka
TomTom One V2 |
Posted: Sat Jan 07, 2006 2:40 am Post subject: |
You an always replace the icons with the icons you like from another set. i.e. take the zSpeed Cam - UK.bmp and rename it to pocketgps_uk_gatso_20.bmp, pocketgps_uk_gatso_30.bmp, pocketgps_uk_gatso_40.bmp etc |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15150 Location: Bradford, West Yorkshire
Posted: Mon Jan 09, 2006 1:26 pm Post subject: |
andspenka wrote: | As far as I can remember it was just to put them to the bottom of the list, so when you're searching your custom points you don't get a load of cameras in the middle of your other POI's. |
that's correct.
also, i use the ones from the main download cos i don't like having individual files for each speed...
MaFt |
Posted: Tue Jan 10, 2006 9:22 pm Post subject: |
Thanks for the replies everyone. |
timbouk Occasional Visitor
Joined: Dec 26, 2005 Posts: 39 Location: Bradford, UK
Posted: Sun Jan 15, 2006 9:27 pm Post subject: Re: Gatso and Truvelo |
StellaMaris wrote: | On the files there are none for the Truvelo? Are these actually in the Gatso files, but just named Gatso for the Garmin GPS's?
I think they must be |
Can I suggest that the truvelo are kept seperate. These work by clocking you between the cameras, ideally need to know the distance between a pair and adjust the warning distance to suit. Does that make sense? |
Oldboy Pocket GPS Moderator
Posted: Sun Jan 15, 2006 9:37 pm Post subject: Re: Gatso and Truvelo |
timbo_uk wrote: | Can I suggest that the truvelo are kept seperate. These work by clocking you between the cameras, ideally need to know the distance between a pair and adjust the warning distance to suit. Does that make sense? |
Truvelos do not measure an average speed. They are a camera that takes a photo of the front of the car as you cross strips laid in the road.
Specs are the cameras that measure the speed between 2 cameras. _________________ Richard
Posted: Sun Jan 15, 2006 9:59 pm Post subject: |
oops, i was really sure that the truvelos did that. Sorry ;)
OK then, are specs kept differently? |
