Pocket GPS World :: View topic - Get data out from streetpilot i3
steveapp
PostPosted: Sun Jan 01, 2006 11:17 pm    Post subject: Get data out from streetpilot i3 Reply with quote
Hey all
I would like to extract location information from my i3 on the move, in theory this should be easy enough to do as I suspect the data is fed out of the usb port for use on a pc, but is there any wiring diagrams on the web as to how I could get this out - how to wire the cable maybe ?
My theory is to make a new usb power lead out of a normal big to small and make a break out box somewhere i can plug the ower supply into and perhaps a second usb socket to connect a laptop or perhaps my treo phone to grab data etc...
Any thoughts out there ??
Stephen
mcintyre
PostPosted: Mon Jan 02, 2006 1:23 am    Post subject: Reply with quote
I don't think it will send data out through the USB port when in use TBH - AFAIK the data from the antenna is processed internally and there would be no use in sending it anywhere else.
I could be wrong though....
steveapp
PostPosted: Mon Jan 02, 2006 1:49 am    Post subject: Will check again when i have a moment but.... Reply with quote
I have a mapsource cd that came with an older e-map (useful for adding favorites etc) and Im sure I managed to get it to show me where i was live when I had it plugged into my pc directly to upload favorites etc - but I could be mistaken it was a while ago when i did that, i could be getting myself confused (easily done these days sadly - Laughing Out Loud)
Stephen
Skippy
PostPosted: Mon Jan 02, 2006 2:13 am    Post subject: Reply with quote
The older GPS units used to send NMEA data out their serial ports. I'm pretty sure the newer ones do the same with the usb port.
You could try nroute from Garmin and see if that works with it.
Gone fishing!
Aitch2
PostPosted: Mon Jan 23, 2006 1:14 pm    Post subject: Reply with quote
Hmmm - I have MS AutoRoute 2005 on a laptop - and that only shows serial connections available to be configured for accepting external NMEA data from (ie. no USB option) ...any idea whether I can somehow attach my Streetpilot i3 to my laptop to 'drive' Autoroute in this way, please??
Aitch
Ash10
PostPosted: Mon Jan 23, 2006 1:21 pm    Post subject: Reply with quote
USB Garmins use a proprietory format, not NMEA - however, IIRC GpsGate can patch this through to NMEA on a virtual COM port.
Aitch2
PostPosted: Mon Jan 23, 2006 2:03 pm    Post subject: Reply with quote
Ahhhhh - yesssss - DEEP JOY!
He was spot on, you know! 8)
All you i3 owners who want to derive positional NMEA-compliant data from your units - using the standard supplied USB cable - really want to see this:
http://franson.com/gpsgate/download.asp?file=GpsGate.zip&ok=1
...and all for under £10 a copy licensed (Express Version).
A very happy,
Aitch
Ash10
PostPosted: Mon Jan 23, 2006 2:07 pm    Post subject: Reply with quote
Glad to be of service... :D
22.062 (12 Jun 24)
