Pocket GPS World :: View topic - Full postcodes TTN5.210
Gatesy
PostPosted: Wed Nov 30, 2005 9:31 pm    Post subject: Full postcodes TTN5.210 Reply with quote
A friend of mine has a HP Ipaq 2210. He let the battery run down & lost the data. I helped him re-install from the CD's & also updated from TTN5.000 to TTN5.210. However, both before & after the update it would only do a postcode search up to 5 digits.
On the SD card, there are 2 folders, "Great_Britain-Map" & "Zip". I am led to understand that "Zip" is the folder that contains the info for postcodes. I have tried again from the CD but still no joy. The folder "Zip" contains a file called "Great_Britain.Postal" which is 8.41Mb.
Anyone have any ideas what is needed to enable full 7 digit UK postcode search on this as i am stumped.
HELP!
Best wishes.
Gatesy.
kartracer
PostPosted: Wed Nov 30, 2005 9:40 pm    Post subject: Reply with quote
There should also be a folder called TOMTOM on the SD card. It can be empty.
Kam
Gatesy
PostPosted: Wed Nov 30, 2005 10:10 pm    Post subject: Reply with quote
No folder on the card other than the one's previously mentioned. There is a file on the PDA called "TomTom". Unfortunately, when I started this topic, I was at my friend's house but i am now at my house & do not have the PDA with me at present. Going from memory though, I believe the folder "TomTom" had files in it, but I don't recall what they were called.
Best wishes.
Gatesy.
Tim Buxton
PostPosted: Wed Nov 30, 2005 10:11 pm    Post subject: Reply with quote
You can make the folder yourself.
Tim
Gatesy
PostPosted: Wed Nov 30, 2005 10:14 pm    Post subject: Reply with quote
So I have to create a folder called "TomTom" & put it onto the SD card, leaving the folder "TomTom" empty?
Best wishes.
Gatesy.
PostPosted: Wed Nov 30, 2005 10:28 pm    Post subject: Reply with quote
That's correct. Put it in the Root of the SD card, at the same level as the Zip Folder.
Yes that is all that is required a TomTom folder in the root of the SD card and should all work fine - Mike
Edit - Sorry Richard - double post with the same info -Mike
Gatesy
PostPosted: Wed Nov 30, 2005 11:54 pm    Post subject: Reply with quote
I shall give that a go. Thanks guys.
Best wishes.
Gatesy.
richard_ha
PostPosted: Thu Dec 01, 2005 1:01 am    Post subject: Reply with quote
the ZIP folder have to be in "My Documents" on the device...
"My Device\My Documents\ZIP"
Like that.
alix776
PostPosted: Thu Dec 01, 2005 10:25 am    Post subject: Reply with quote
with thw lastest update the empty tomtom is included just selct to install this as well as the update and postcodes should work fine
device Lumia 950 xl
gigino
PostPosted: Fri Dec 02, 2005 8:01 pm    Post subject: Reply with quote
I'm having the same problem with the postcode I only get for example SW18 (London)
If I put SW183DA I only get SW18 (London).
I've done evrything I've got a folder in the root of the SD card called TomTom and any Called Zip, but still I cannot get the 7 digital postcode.
I've look in the CD but they is only Postcode for London and One for the Netherland.
I've ask this question befor but I got a reply say not to ask for crack I'm a full register user of Tom Tom and I do not belive in crack versions.
Please somebody help.
I have the Tom Tom Navigator Mobile 5 and on that it gives me the full 7 digital postcode.
Regards
Gigino
gigino
PostPosted: Fri Dec 02, 2005 9:01 pm    Post subject: Reply with quote
rforgot to say in previous message the zip folder has 2 file 1 called Great_Britain.postal and setup.dat.
Is this correct because I've deleted the zip file from my pda and the tomtom folder and I still get a postcode like this SW18 (London).
So to me it looks like that it is not reading the files in the zip folder.
Am I right in thing this.
I've upgraded to the 5.2 version but it has installed it in the main memory I what let me choose where to install it. I would like to install it in the storage card.
I could copy it to the storage card and make new shorthcut but how can I get the shortcut on the today screen to look in the stoarge card.
Regards
Gigino
SHADOW
PostPosted: Sun Dec 04, 2005 4:48 am    Post subject: Reply with quote
gigino wrote:
Regards
Gigino
..hi gigino...locate the file that is named "zip" and drag it into the "my documents" folder on your device using activesync..this will give you full 7 digit postcode.. Jumping With Joy
COMPAQ 3970-TOMTOM V5.210-TOMTOM BLUETOOTH RECEIVER
PostPosted: Sun Dec 04, 2005 7:39 am    Post subject: Reply with quote
The above will work, and is what is posted on the TomTom web site FAQ's but it consumes valuable memory, if you follow the advice to create the empty folder (or update to 5,2 as the installer will create the empty folder) then you will get the more efficiant set-up - Mike
MAB
PostPosted: Mon Dec 05, 2005 5:35 pm    Post subject: Reply with quote
I have just encountered the same problem, trying to get FULL post codes to register. What you need to do is touch on "Navigate to" then go to next page which shows the icon "PostCode". This will give you the option to input the full post code.[[/quote]
22.062 (12 Jun 24)
