Pocket GPS World :: View topic - New StreetPilot User - Please Help
Minx
PostPosted: Fri Nov 18, 2005 1:40 pm    Post subject: New StreetPilot User - Please Help Reply with quote
Hi Guys
I'm an eager beaver and want to use my StreetPiloti3 now! I have read through the "Set up and go!" instructions that came with the Garmin. Planned my route selected Start Navigating and it says its locating satellites and I get no further Question
Firstly apologies for being so dim, i'm usually pretty good with technology. Do I have to install any software ie. the USB drivers on the supplied CDROM before I do anything?
I will read the guide for dummies, boy do I need to.
Go easy with me please Confused
Minx
zogman
PostPosted: Fri Nov 18, 2005 1:57 pm    Post subject: Reply with quote
have you read the sticky:GARMIN STREETPILOT I3 FOR DUMMIES ..lots of info there...
Minx
PostPosted: Fri Nov 18, 2005 2:02 pm    Post subject: Reply with quote
Hi thanks for your reply, i'm reading through it now. As it said Sat up and go I really thought it was as easy as that...
Minx
PostPosted: Fri Nov 18, 2005 2:04 pm    Post subject: Reply with quote
oops set up and go Laughing
zogman
PostPosted: Fri Nov 18, 2005 2:07 pm    Post subject: Reply with quote
locating satellites right at first startup does take a while sometimes..the i3 needs to load an almanac which contains your location etc..
Minx
PostPosted: Fri Nov 18, 2005 2:17 pm    Post subject: Reply with quote
I have had it on for 30mins so far, sat next to my window and it's still searching, is that the norm?
zogman
PostPosted: Fri Nov 18, 2005 2:24 pm    Post subject: Reply with quote
depends which way the window is facing and where the sats are...stick the i3 in the middle of the garden with no obstructions near it ..it will soon pick up the sats..
PostPosted: Fri Nov 18, 2005 2:48 pm    Post subject: Reply with quote
are you indoors? if so then stand outside and wait about 15 minutes - it should pick up the satelites then. on first use it takes a while, but if you use it quite regularly the unit 'remembers' where the satelites last were and can find them quicker - this i the 'almanac' that zogman mentioned
Skippy
PostPosted: Fri Nov 18, 2005 3:07 pm    Post subject: Reply with quote
You aren't much help sometimes, zogman. Rolling Eyes
The sticky says:
22) Place I3 in car, switch it on, choose your destination & drive away.
which is the step that Minx would have gotten to. Confused
Minx, if the GPS doesn't get a fix after 2 or 3 minutes then it may have never had a fix and it will take from 5 to 30 minutes to get a fix. Take it to a place with a good view of the sky and don't move it while it downloads the data.
Once it has had a first fix, it should lock on within a minute or two from cold (off for more than 8 hours) or in 10 to 30 seconds from hot (off for less than 8 hours).
Gone fishing!
zogman
PostPosted: Fri Nov 18, 2005 3:13 pm    Post subject: Reply with quote
skippy ..i do my best and i did later suggest (as you have ) that he took the i3 into the garden for a better sat scan...
Minx
PostPosted: Fri Nov 18, 2005 5:07 pm    Post subject: Reply with quote
Hey guys stop squabbling :D . Have followed the dummies guide (very easy to follow it was too). I believe everything has been installed (fingers crossed). Still yet to find the satellites once again I go in search. Will report back if I get stuck again :P
Thank you
Minx
x
Minx
PostPosted: Fri Nov 18, 2005 5:54 pm    Post subject: Reply with quote
Whey hey it works! Took it for a trial run, doesn't seem sure of a mile... 6 miles aka 1 mile? And has yet to find the speed camera's. Hopefully resolved with a little tweaking.
But thanks so much I just love my ickle StreetPilot! :P
zogman
PostPosted: Fri Nov 18, 2005 5:56 pm    Post subject: Reply with quote
glad to hear that you have got it working....what do you mean by 6 miles aka 1mile?
Minx
PostPosted: Fri Nov 18, 2005 5:58 pm    Post subject: Reply with quote
It said in point 6 miles, when infact it was only about 1 mile in distance...?
zogman
PostPosted: Fri Nov 18, 2005 6:01 pm    Post subject: Reply with quote
maybe just a little settling in glich...
22.062 (12 Jun 24)
