Pocket GPS World :: View topic - GARMIN STREETPILOT I3 FOR DUMMIES - Clarification
John_2811
PostPosted: Thu Nov 10, 2005 5:25 pm    Post subject: GARMIN STREETPILOT I3 FOR DUMMIES - Clarification Reply with quote
Bit of clarification about the above please?
Today I bought a i3 and upgraded the OS to 2.7, down loaded the Garmin POI loader tool and down loaded the Garmin POIs from http://www.MaFt.co.uk/garmin/download.htm
I have read
http://www.pocketgpsworld.com/Garmin%20POI%20Loader%20install.pdf
in this document it says that the speed camera ZIP will have a Garmin folder or the structure, it doesn't. I can see the different files with data structured for types of GPS, but can see no reference to Garmin, only "other".
My question is which of the file/s in pocketgps_uk_sc_oct05 should I extract into the same folder containing the mafts Garmin POIs and BMP files read to be transferred to the i3 with the POI loader tool?
John
PostPosted: Fri Nov 11, 2005 2:12 pm    Post subject: Reply with quote
John, i've been using the ones from here: http://pocketgpsworld.com/uksafetycameras.php
and then you need to extract the 6 csv files from "csv files/other" in the zip file. these need to be unzipped into the same folder as the other POI files. have a look at the readme file in the download from MaFt.co.uk/i3 regarding the bmp's and renaming the files etc.
Logan1475
PostPosted: Fri Nov 11, 2005 2:33 pm    Post subject: Reply with quote
I think if you go to the camera database page and scroll down to garmin there is a link to a page with instructions for downloading the i3 camera database, I think anyway.....I should know I've done this at least three times. Other than that there is a web a guy on the forum called MaFt how has his own webiste with all you need on.
Hope this helps :D
