Pocket GPS World :: View topic - first camera database install
humber
PostPosted: Fri Oct 21, 2005 10:18 pm    Post subject: first camera database install Reply with quote
hi, i have a pda running tt 3 navigator and would like to install the speed camera database, do i need to use poiwarner or checkpoint,at the moment i have nothing installed,thanks for any help.
Pocketgps
PostPosted: Fri Oct 21, 2005 10:50 pm    Post subject: Reply with quote
You can use CheckPOInt for free, POI-Warner requires a purchase registration.
Download CheckPOInt Here
Then download the Safety Camera files from this web site, use the files from the folder called 'ov2 bmp files' open that folder and then copy all the files, then paste them to your Great Britain map folder on your storage card.
You then need to configure CheckPOInt to add each of the files.
Have a look at this page for basic help with CheckPOInt - Here
humber
PostPosted: Mon Oct 24, 2005 7:31 am    Post subject: thanks Reply with quote
hi, thanks you for your advice,this forum is the best, you always get some helpful advice,thanks folks
humber
PostPosted: Mon Oct 31, 2005 8:25 am    Post subject: no sound files Reply with quote
hi, i have installed checkpoint and copied the cameras (ov2 bmp) on to my sd card, when i go into the properties of each camera i cannot find any sound files anywhere, i have them in the speed camera folder on my desktop(wav files) do i need to copy and paste them into the gb maps or a differant location.thanks
Pocketgps
PostPosted: Mon Oct 31, 2005 7:49 pm    Post subject: Re: no sound files Reply with quote
The .wav files can be copied and pasted to the map folder on your storage card. You should then be able to find them and configure each different poi with which ever .wav file you require.
humber
PostPosted: Mon Oct 31, 2005 11:40 pm    Post subject: sorted Reply with quote
hi, thanks for your help they are all set up now, would you know what speed cam database you need to install them on a nokia 6600,and is it the same method,thanks
Pocketgps
PostPosted: Tue Nov 01, 2005 8:51 pm    Post subject: Re: sorted Reply with quote
Sorry, can't help you with that one.
PeirreOBollox
PostPosted: Tue Nov 01, 2005 10:16 pm    Post subject: Reply with quote
can`t use this wersion on my PDA for some reason
it states "this version was designed to be used on earlier version of windows software
Pocketgps
PostPosted: Wed Nov 02, 2005 5:06 pm    Post subject: Reply with quote
Which operating system is installed on your PDA, unit make and type ?
GPS software make and version ?
Also what poi warning system are you refering to, POI-Warner or CheckPOInt ?
22.062 (12 Jun 24)
