Pocket GPS World :: View topic - How to Select POI in Enable POI sub Menu
MartinE
PostPosted: Mon Oct 17, 2005 10:36 pm    Post subject: How to Select POI in Enable POI sub Menu Reply with quote
Hi All,
Maybe someone can offer some advice on this problem. I have in the past copied POI's into the map folder on the SD card and then selected them in enable POI and then set up the warning audio. This has worked fine until I copied in a POI called Airfields. The ov2 and bmp files can be clearly seen in the Map folder but cannot be seen in the enable section of POI's sub menu, so therefore cannot be selected.
Any clues anyone please,
Regards and Thanks,
Martin.
Tim Buxton
PostPosted: Mon Oct 17, 2005 10:48 pm    Post subject: Reply with quote
There is a limit to the number of POIs you can have. Could it be that you've reached the limit? Try deleting or disabling one of your other .ov2 files (or renaming one) and see if Airfields can then be selected.
Tim
MartinE
PostPosted: Mon Oct 24, 2005 9:48 am    Post subject: Thanks for the Help Reply with quote
Hi Tim,
Well I did as you suggested and now all is OK so there is a limit to the number of POI's that you can have active at the same time. I found that disabling then did nothing I had to actually delete them then bingo. So thanks for your help on this one,
Martin
