danoli Occasional Visitor
Posted: Tue Sep 27, 2005 6:13 pm Post subject: My i3 review + help requests |
Just got my i3 yesterday.
I was initially worried about the small screen as I have a PDA GPS plus the Garmin GPS-V and the GPSMAP196 which all have larger screens.
I was suprised at how effective the screen really is for its size. Obviously with a larger screen you can pull up lots of other information, speed, time, ETA, DTA etc but I mostly look at the moving map so no real loss.
The two button interface is so simple to use (yep, I know it has 3 buttons, but one is on/off only)
I have been able to input nearly 100 custom waypoints within a very short space of time, the GPSMAP196 and GPS-V with all their buttons takes much longer.
I ran the i3 against the GPSMAP196 and a 200 mile route took a simillar time to calculate, they differed by 4 miles so I will check the difference on friday when I drive the route.
On short trips, both the i3 and GPSMAP196 were identical on calculation, route and values (speeds, warnings and distance).
Niggles:
I have found no way of displaying the current speed when navigating, it does show in the map view when not navigating.
Voice prompt only says "1st" or "2nd" whether it is the first or second turning on the left or right or junction off a roundabout.
Viewing favourite finds (waypoints) lists them by proximity, I cannot find a way to sort them alphabetically (this is a big let down with potentially 500 waypoints)
Waypoint names can only be input in correct case, i.e. first letter capital, I cannot find a way of forcing all uppercase or lowercase names.
The scroll wheel can be a little 'touchy' at times and you can sometimes hit the wrong selection and have to go back to correct it. I am sure this is just a case of getting used to it. It seems to have a small delay when you first use it, eg. Entering a waypoint name, the first movement of the wheel invokes a slight delay, almost like a dead spot on the wheel, after that it works instantly. (unless mine is faulty)
More to follow..... |
upthegardenpath Occasional Visitor
Posted: Tue Sep 27, 2005 9:52 pm Post subject: Re: My i3 review + help requests |
danoli wrote: | .....Voice prompt only says "1st" or "2nd" whether it is the first or second turning on the left or right or junction off a roundabout...... |
Danoli...
...it should say "turn left", "turn right", "enter roundabout and take 3rd exit "(etc)
Have you downloaded software release 2.4 yet?
Reading other posts in this forum, people with "voice problems" have been advised to change the language to another and then back again
see this from swampmonster (sep 11 '05)...
"I posted a question at Garmin support re the problem I was having with voice commands and the hanging problem. Customer Support at Garmin Support seems a really good guy and responds quickly. The master reset on it's own didn't solve the problem and I wrote again and he suggested doing the master reset again but when it asks you for a language choose
a non english option. Then once that has been installed you will need to
then change the voice back to English. It might be worth noting that I waited whilst the language files loaded and didn't press the wheel as instructed, after about five minutes it went the next option on it's own. This worked brilliantly and I now have a unit that seems to work. "
Or you could ring Garmin Customer Support (0870-8501242 ) who have been helpful, by the sounds of things others have said. |
Posted: Tue Sep 27, 2005 9:56 pm Post subject: |
just to say...
if you do the master reset , you will lose all your user defined data but IMHO its better to do it now and get it working properly, then reload all your data |
Posted: Tue Sep 27, 2005 10:19 pm Post subject: |
Ahh, I think the problem was when I first switched it on. Chose the English language then waited for about 2 minutes. After about 2 minutes I thought it had locked up so I powered it off then on. So I probably interupted the voice file download... |
Posted: Tue Sep 27, 2005 10:26 pm Post subject: |
Sorted it. Switched the languages to another and back again. Patience...... |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15154 Location: Bradford, West Yorkshire
Posted: Wed Sep 28, 2005 2:43 pm Post subject: |
i was going to say that mine has said previously "take the 6th exit from roundabout" but upthegardenpath beat me to say about resetting the voice files...
regarding speed when you're driving - the speedo on the car is much more accurate... i wouldn'y rely on the one from the i3 alone!
my only niggle is as follows:
no way to get lat/long details from favourites and therefore no way to back them up without going to a mapping website, finding the area and doing it that way round. |
Posted: Wed Sep 28, 2005 3:06 pm Post subject: |
MaFt wrote: | regarding speed when you're driving - the speedo on the car is much more accurate... i wouldn'y rely on the one from the i3 alone! |
I am suprised you find that. GPS with good sat coverage will geve very precise speed, far better than the average car sppedo which can be 10% out. My car is doing 61mph when indicating 70mph...
I have compared the GPSMAP196 with the i3 when not navigating the the speed comparison is identical. Both gave excellect sat coverage. I have confirmed the GPSMAP196 against numerous other devices including police speed cameras (friends in the police )and the accuracy is second to none. |
Posted: Wed Sep 28, 2005 5:42 pm Post subject: |
but the speedo in the car is constantly updated, the satnav will check satellite locations periodically giving possible misleading speeds every so often...
just my opnion though
MaFt |
Posted: Wed Sep 28, 2005 7:38 pm Post subject: |
MaFt wrote: | but the speedo in the car is constantly updated, the satnav will check satellite locations periodically giving possible misleading speeds every so often...
MaFt |
The GPS (assuming good coverage) updates every second giving pretty good accuracy, unless you have a really fast car that can accelerate more than 10-15 mph per second, then it would be inaccurate (during acceleration). During a normal cruising without much speed fluctuation, the GPS can give accuracy far greater that a standard fit car speedo.
I always keep my eye on the car speedo though, just in case of gross errors on the GPS. |
andspenka Occasional Visitor
Joined: Sep 22, 2005 Posts: 24 Location: Co. Durham U.K.
Posted: Thu Sep 29, 2005 7:12 pm Post subject: |
MaFt wrote: |
GPS speed is much more accurate than a car speedo.
I've just sold an ex police Vectra which had a calibrated speedo with 2 mph increments, ie; the one which is fitted to all the Traffic cars. Unfortunately I didn't have the i3 when I had the Vectra but, we have some of those Your Speed signs around our area which I checked my Vectra against and the speeds were exactly the same.
I have also checked the speedo in my Mam's car, my motorbike, bro-in-law's car and a friends car and they all have a few MPH's error to the signs, leading to the fact that all car speedo's have an amount of inaccuracy to them.
I haven't checked the i3 against the speed signs yet but when I do I will post the results. _________________ Andspenka
TomTom One V2 |
Ramases Occasional Visitor
Posted: Sun Oct 02, 2005 1:31 pm Post subject: |
Popped my i3 into my wife's Seicento last night to check speedo accuracy. At all speeds above an indicated 30mph it was reading 5mph over the GPS indicated speed. My understanding is that speedos in the UK may read up to 10% fast, so hers is clearly outside this tolerance. My feeling in that the i3 is MUCH more accurate than the car. At 30, it just feels like 25 and would explain why she seems to have a long queue behind her on speed-limited roads! |
MELennium Frequent Visitor
Joined: Sep 25, 2005 Posts: 337 Location: County Durham
Posted: Sun Oct 02, 2005 2:01 pm Post subject: |
As i said earlier i have also the micro road pilot which detects safety cameras as well as the i3 and working side by side the i3 is spot on with the pilot. On there web site they say it is much more accurate than any car speedo, so yes the i3 speed is spot on. |
Posted: Mon Oct 03, 2005 6:07 pm Post subject: |
Ramases wrote: | Hi
Well, today I tried it in my new Tigra. Speedo just 1mph above i3 indicated speed from 30 to 60 ............. |
blackrat62 Occasional Visitor
Posted: Mon Oct 03, 2005 8:28 pm Post subject: Speed accuracy |
The Garmin will be more accurate than your speedo.
The 10% rule went out many many years ago (many officers don't even know that!!) - believe it or not there is an EU formula for speedo error.
The formula is as complicated as you would expect from the EU - what was wrong with the 10% I ask.
No speedo is allowed to under-read BUT at 70mph the formula allows for about 17% over-reading. Yes that is 17%.
God bless Europe.
i3 - great piece of kit. |
ninjagaiden Occasional Visitor
Posted: Mon Oct 03, 2005 9:52 pm Post subject: |
Sorry to be stupid but ...
There obviously is a way to get i3 to display vehicle speed, but I can't work out how to do this. Have fiddled with unit and also checked manual.
I'd be grateful if you could explain how this is done.
Thanx |
