Pocket GPS World :: View topic - TT5 Palm update V5.12 -possible problem
smike
PostPosted: Tue Aug 23, 2005 11:16 am    Post subject: TT5 Palm update V5.12 -possible problem Reply with quote
I've just loaded the TT5 Palm V5.12 update.
However I'm not sure it has installed properly.
2 new files (cn.prc and start.prc) have loaded, however the TT version information still shows I have version 5.000.
Also I still get the "Possible database overwrite problem." when I sync.
Has anybody else experienced this?
PostPosted: Tue Aug 23, 2005 2:43 pm    Post subject: Reply with quote
why don't you clean it out and reinstall from scratch? It says "update" but in reality it's always a full version.
masterzone
PostPosted: Wed Aug 24, 2005 4:40 pm    Post subject: Reply with quote
It's happen to me, now you have the program "navigator" updated (as launcher of tom tom) and the tom tom still 5.000
Tomorrow I've done the upgrade...and now it's don't turn off based on system prefs.
When you start the upgrade, there is a moment where tom tom say to you "now you can make a transfer"...in this moment!!! you must click on Hotsinc on Palm, and choose the TOMTOM card....
And all goes fine
Finlab
PostPosted: Sat Aug 27, 2005 8:43 pm    Post subject: Reply with quote
what are the advantages of upgrading? doesnt seem much from tomtom site.
masterzone
PostPosted: Tue Aug 30, 2005 10:37 am    Post subject: Reply with quote
Boh, I don't know, I continue do get some total freeze when it's re routing...or casually freeze...
Alex
Mz
ndy4eva
PostPosted: Sat Sep 03, 2005 9:22 pm    Post subject: Reply with quote
Mine just freezes up while re-routing, when I have MP3 playing on background. Without MP3 playing, it works great..
I have T|T5, GlobalSat BT-338, and TomTom v5.12.
Mr-B
PostPosted: Sun Oct 02, 2005 1:07 pm    Post subject: Another failed upgrade to v5.12 Reply with quote
I've just tried this without success. Sad
As the OP noted, I see two new files loaded and Hotsync error log has multiple lines like this:
-- Possible database overwrite problem. Backing up database great_britain-24a02c86.mac to file C:\...\Backup\great_britain-24a02c86_mac.PDB. The file contained database great_britain-24A02C86.mac data.
TTN still says v5.00.
I'm sure the original v5.00 installer allowed you to install to the SD card directly which is a lot quicker than Hotsyncing, but the v5.12 upgrade didn't give me the choice this time.
Any ideas how to fix this?
MikeProcter
PostPosted: Mon Oct 03, 2005 10:14 am    Post subject: Reply with quote
I used to have these problems.
In the end I got fed up of lots of little problems that I performed a zero out reset on my Treo. This put it back to factory state. It is hard to do but it is even better than a hard reset. Don't forget to hotsync first.
I also renamed my profile to old so that I could start afresh with everything.
I installed TTN5.12 direct. It does not need to be upgraded from 5.
Then I installed the maps. I only use the GB maps as the plus ones make recalculation times very long. When I need to go into Europe I'll add the plus map.
Then I activated the map and so far have had no real problems other than TTN causing a reset every now & then.
This method is a bit drastic, but it has stopped all the problems I was having.
Skoda Columbus and for emergencies: TomTom + iPhone 4 & TomTom car kit
