wildatheart Occasional Visitor
Posted: Thu Sep 01, 2005 10:40 pm Post subject: Permanent Docking Kit; link to headlights=faulty? |
With the Permanent Docking Kit you are supposed to be able to link the night vision of the maps to the car headlights. But when I select this from the docking preferences screen , the TomTom immediately switches to night view; I dont even have to switch the headlights on. I can only turn it back to day mode when I untick the LINK TO HEADLIGHTS option.
Has anyone got this feature to work as intended? _________________ 1970 Mercedes W113 280SL
1986 Ford Capri 280 Brooklands
1996 BMW 840Ci Sport |
rkm_hm Frequent Visitor
Joined: Nov 28, 2004 Posts: 532 Location: Warwick, UK
Posted: Thu Sep 01, 2005 11:23 pm Post subject: |
If it's installed in one of your Volvos with permanently-on headlamps, it is perhaps not surprising!
_________________ Roger
TomTom via135
Satmap Active 10+ v1.50 with full UK 1:50k map and 1:25k/1:10k County maps of Hampshire & Warwickshire |
Posted: Thu Sep 01, 2005 11:59 pm Post subject: |
rkm_hm wrote: | If it's installed in one of your Volvos with permanently-on headlamps, it is perhaps not surprising!
Nice thought . Though sadly the problem exists even when the relevant (orange) wire in the Docking Kit harness is disconnected. So it appears this is a problem with the Docking Kit itself. _________________ 1970 Mercedes W113 280SL
dill Regular Visitor
Posted: Fri Sep 02, 2005 2:07 am Post subject: |
Dont buy Permanent Docking Kit.
Every post I have read says problems PROBLEMS.
I guess you guys are the guinea pigs, hard lession learnt but dont buy the first edition.
Sorry for being so negative. |
Posted: Fri Sep 02, 2005 9:30 am Post subject: |
I don't regret buying the kit as hearing the directions through the car speakers (and having the radio automatically muted), and the external aerial make it worthwhile in itself. The headlights option is more of a fun-thing, but I do agree with you, that if other users can't get it to work either, it is clearly a flaw in the design. And as such, that particular aspect seems not have been tested sufficiently. _________________ 1970 Mercedes W113 280SL
onezone Occasional Visitor
Posted: Fri Sep 02, 2005 11:28 am Post subject: |
Just in case people ask WHat car..
if it makes any difference..
I use my kit in a Mercedes and it doesn't work with the headlight option either.. |
sdb2005 Occasional Visitor
Posted: Wed Sep 07, 2005 6:52 pm Post subject: |
I have just installed mign myself and I have had no problems.
I have a pic of the headunit wiring if you want to compare to yours.
Have you tried a different go?
I noticed on the VIB it said V2 perhaps they had problems with V1. |
TuurG Frequent Visitor
Joined: Nov 23, 2004 Posts: 454 Location: Haarlem, The Netherlands
Posted: Wed Sep 07, 2005 9:06 pm Post subject: |
wildatheart wrote: | rkm_hm wrote: | If it's installed in one of your Volvos with permanently-on headlamps, it is perhaps not surprising!
Nice thought . Though sadly the problem exists even when the relevant (orange) wire in the Docking Kit harness is disconnected. So it appears this is a problem with the Docking Kit itself. |
You are not running v5.202 with the special apps from ScaredyCat, with Autoswitch? |
Posted: Wed Sep 07, 2005 9:07 pm Post subject: |
Your headlights should give a +12V signal to trigger night mode, and ground signal for daylight mode. |
Posted: Thu Sep 08, 2005 4:08 pm Post subject: |
Here is the wiring for my headunit.
