Pocket GPS World :: View topic - Medion 95900 win ce net 4.2 core build 1088
binbags
PostPosted: Sun Jun 26, 2005 2:19 pm    Post subject: Medion 95900 win ce net 4.2 core build 1088 Reply with quote
Hi everyone
have just spent 2 hours getting my taskbar on my medion 95900.
All this was with the help of MrRee4U, noot quite sure if i found him on this forum, anyway if not i am sure he visits this one. Many thanks to him.
Being new to all this and being of the over 60 gang, i think i did quite well.
Now to the next main issue on my list,
I would like some help to install POI-Warner and a speed camera database, not sure if i should use the POI one or one of the UK free ones?
Then onto the next subject (UKPC2NVG) post code program help?
So if anyone out there feels like giving an old man a lift, i would be gratefull.
regards to all, in anticipation.
heliflyer
PostPosted: Sun Jul 03, 2005 6:36 pm    Post subject: medion 95900 Reply with quote
hi are you still in trouble?
binbags
PostPosted: Mon Jul 04, 2005 7:29 pm    Post subject: Reply with quote
Hi heliflyer
Thanks for asking. i have now solved my problems. all that remains is to sort out what i do and dont need from the poi-warner database, this is proving tiresome but all things are sent to try us. :D
i have not yet ventured onto the seven digit postcode program, but i will when i have more time in front of the pc. 8) Laughing
thanks once again, i will remain in touch.
SCO7T
PostPosted: Thu Jul 07, 2005 3:41 pm    Post subject: Reply with quote
hi there
just letting you know i installed poi warner and all the speed cameras onto my medion 95900 (200s) using this link below
its a complete step by step to doing it
http://www.amngps4.wanadoo.co.uk/poicon.htm
hope it helps you
regards
scott lewis
binbags
PostPosted: Thu Jul 07, 2005 5:36 pm    Post subject: MD 95900 Reply with quote
Hi sco7t
Good to see that you have mastered the medion, as i did.
i am still playing with it and learning, the next step is to install a program called ukpc2nvg, this is a program that use can use for seven digit postcodes.
keep me imformed of your developments.
regards
SCO7T
PostPosted: Thu Jul 07, 2005 10:40 pm    Post subject: Reply with quote
hi binbags
just managed to hack the system to get the taskbar
really cool bit of kit now
i just have one question
when i load up medion navigator 4.75 everything ios fine
but once poi warner loads up i get a load of boxes apear on the left hand side of the screen in different colours
have you had the same problem
still get it after hard reboot
many thanks
sco7t
scott lewis
binbags
PostPosted: Fri Jul 08, 2005 5:29 pm    Post subject: MD95900 Reply with quote
Hi Scott
You may have to reinstall poi-warner again
all you should have after you started to monitor is medion navigator loading then once this has loaded you should get one small green square in the lower left of the screen.
I am only a beginner like yourself, but keep trying.
I found out by accident that if you do a hard reset with the power switch on the back of the unit, that you loose everything that you have installed!
Good look
binbags
22.093 (18 Sep 24)
