gimp Occasional Visitor
Posted: Sun Jun 26, 2005 6:55 pm Post subject: Medion 95900 and ActiveSync. |
I cant get activesyn to set up a partnership with my medion 95900. I get an error message saying that there's a problem with a file and to restart the system and try again. I do this and...Same problem! Anyone had this situation and found a cure? |
shaun_uk Occasional Visitor
Posted: Mon Jun 27, 2005 2:18 pm Post subject: |
i get same message.just click ok and ignore it. i can still send and recieve info to and from medion to pc so no worrys. |
tel33 Regular Visitor
Joined: Mar 23, 2005 Posts: 159 Location: UK Portsmouth
Pras Occasional Visitor
Posted: Mon Jun 27, 2005 8:11 pm Post subject: |
no it won't help.
according to medion tech support it can't establish a partnership.
only guest account is possible as it is a PNA and not a PDA... |
Posted: Mon Jun 27, 2005 10:49 pm Post subject: |
Sorry thats wrong about not being able to set up a partnership as mine can and thats a PNA175 and that is not a guest partnership but a full one. |
Posted: Tue Jun 28, 2005 1:34 am Post subject: |
sorry but that;s what medion's support team told me.
then again maybe you know better. |
Posted: Tue Jun 28, 2005 8:05 am Post subject: |
Then again I do have it in front of me with a partnership of Adygps on it so how do they explain that then? |
Posted: Thu Jun 30, 2005 4:36 pm Post subject: Medion 95900 and ActiveSync. |
Thanks to you guys for your help. I've sold the Medion and bought an Acer N35 with satnav. The software isn't as good but there must be an alternative I can load that won't cost an arm and a leg. Anyone got any suggestions? |
Waffty Occasional Visitor
Posted: Fri Jul 01, 2005 2:59 pm Post subject: Re: Medion 95900 and ActiveSync. |
I too spoke to Medion and was told that the 95900 won't setup a Partnership, as the OS isn't a full blown version of CE.
Before speaking to them, I tried it on three PCs (W2K SP3, W2K SP4 & XP professional SP2), I then tried the latest version of ActiveSync 3.8 on all the above and it still didn't work.
I then confirmed with Medion that the 95900 (200S) wasn't able to setup a partnership, nor were you able to backup in Guest mode.
Now if anyone would like to say otherwise, then let me know, as I'm getting a little hacked off with POIWarner re-installations when the battery dies.
Waffty
Posted: Fri Jul 01, 2005 4:15 pm Post subject: |
Iam sorry I really dont understand what the problem is?
I have a partnership with my PNA175 and have backed up my PNA175 many times and restored it on many occassions and all in non guest mode e.g with a partnership.
I use Activesync 8 with this and my 2 Ipaqs that I have and have no problems whatsoever with it.
Still thats all I am going to say on this as its obviously not making one bit of difference that I can do it yet Medion say you cant!
Still if they say it cant be done then who am I too say otherwise if mine is working perfectly?
Goodluck
Regards
tel33
P.S Iam looking directly at my Activesync connection and the partnership (Adysgps and not a guest partnership I might add) I have with it right now and I can move files etc with no problems and it is synced up with no problems whatsoever so make of that what you will Medion ![Gun Shoot Out](modules/Forums/images/smiles/custom11.gif) |
Posted: Fri Jul 01, 2005 5:49 pm Post subject: |
Activesync 3.8.0 (Build 5004)I meant :-) |
Posted: Sat Jul 02, 2005 8:38 am Post subject: Re: Medion 95900 and ActiveSync. |
tel33 wrote: | I have a partnership with my PNA175 and have backed up my PNA175 many times and restored it on many occassions and all in non guest mode e.g with a partnership. |
Maybe that's it ? The Medion 95900 is PNA200S and not a PNA175.
So whilst it may work ok on a PNA175, I can deffo tell you it doesn't work on a PNA200S, as per my experiances and as per the info from Medion.
Waffty
