Pocket GPS World :: View topic - TomTom Navigator 5 Favorites
an2ony17
PostPosted: Sat Jun 25, 2005 6:52 pm    Post subject: TomTom Navigator 5 Favorites Reply with quote
Is their any way of backing all of the favourites contained within TomTom
Navigator 5?
I use an XDA2S which sometimes hard resets, I hate loosing all of my
favourites each time.
Anthony.
Mystery
PostPosted: Sat Jun 25, 2005 7:10 pm    Post subject: Reply with quote
In TTN5 I have stopped using favourites. I have created a POI Catgeory of Favourites instead. You can 'import' your favourites to become POIs and so able to save them as POI instead. So by copying your Favorites POI to your computer you can save them.
This may solve your problem of losing Favourites when hard reset occurs.
The How To:
Go to Manage POI
Add POI Category of Favourites (or whatever you want to call them)
Add POI now to that category and you can select from your Favourites
Once all have been copied over to become POI Delete the favourites.
Hey Presto savable and exportable Favourites {PS you can also have your new Favourites (POI) show on map under enable/disable POI}
an2ony17
PostPosted: Sat Jun 25, 2005 11:43 pm    Post subject: Thanks Reply with quote
Thanks for replying, I have created a new POI group and imported all of my favorites, it works a treat.
Where is the POI file located to backup, is it the one on the SD card within the Great Britain Map folder?
Anthony.
Mystery
PostPosted: Sun Jun 26, 2005 10:15 am    Post subject: Reply with quote
The group and all the POIs are now located in you main map folder on the SD card. Just use active sync and look for the group you named and copy the ov2 file and the bmp file to somewhere safe and if you need to re-install etc then you can just copy them back again. It is unlikely that even a hard reset will clear the map folder on an sd card. Hard reset really just re-installs the base programs on the PDA not affecting the SD card.
an2ony17
PostPosted: Sun Jun 26, 2005 2:21 pm    Post subject: Thanks Reply with quote
Got it, thanks.
