ferjan Occasional Visitor
![](modules/Forums/images/avatars/gallery/spherewall.gif)
Posted: Thu Jun 16, 2005 4:50 pm Post subject: Poi and Medion 95900 |
I have got Poi speed camera software installed on my MD95900...one question..how do you access it please, if you tell me via Activesync then I have got another problemas I can not get Activesync to work on my computer.. everytime I try and run it I get the message there is a problem with Activesync you need to rerstart you computer to resolve this problem...so I do that and it's still the same old message any help on these would be appreciated.
P.S I am running XP pro and SP 2 if that helps. |
chippy436 Occasional Visitor
Posted: Thu Jun 16, 2005 6:43 pm Post subject: |
i am stuck with the poi, but i had the same issue with activesync, i had to remove it from my pc and then restart the pc and then re-install activesync.. this worked on the 2nd attempt.. was very frustrating..
but try removing it then restart and re-install. |
Posted: Fri Jun 17, 2005 10:05 am Post subject: Thanks |
Thanks Chippy436 I will give that a try...lets hope it works hi. |
Waffty Occasional Visitor
Posted: Mon Jun 20, 2005 6:07 pm Post subject: Re: Poi and Medion 95900 |
ferjan wrote: | I can not get Activesync to work on my computer.. everytime I try and run it I get the message there is a problem with Activesync you need to rerstart you computer to resolve this problem...so I do that and it's still the same old message any help on these would be appreciated.
I've had a similar problem i.e Activesync doesn't appear to work out of box in partnership mode but it will allow me transfer files via the guest mode option.
I'm interested in performing a full backup (in guest mode) but everytime I kick it off, it complains that the "disk is full". I've changed the preference location for the Backup.stg file but I still get the same error.
So I guess my question is, can I backup my system in guest mode and why can't I setup a partnership ?
Also, even using guest mode, I managed to get the POI working. I simply found a copy of taskbar hack. Copied it into the start up folder, rebooted and followed the instructions from this site.
Many thanks in advance.
GPS_RoadHog Occasional Visitor
![](modules/Forums/images/avatars/gallery/090.gif)
Posted: Mon Jun 20, 2005 6:23 pm Post subject: |
I have discovered there is no need to hack the os / install task bar to install speed camera software. _________________ TomTom Via 135 |
qwackers Occasional Visitor
Posted: Thu Jun 30, 2005 11:52 am Post subject: |
read somewhere that partnership won't work as it is a PNA not a PDA (the 95900 that is) though you can still copy/delete files ok in guest mode.
As for the backup, I'm also looking for an answer to that one. |
Hooloovoo Regular Visitor
Joined: Jun 20, 2005 Posts: 90 Location: Midlands, UK
Posted: Thu Jun 30, 2005 12:06 pm Post subject: |
The only thing you need to back up are the favoruites.txt file which contains all your saved locations, and the contents of your routes directory which contains any multiple-destination routes that you've saved.
Everything else is on the CD that came with it. Plus, if you haven't edited anything on the memory card you don't even need the CD. Just switch it off on the back and then on again and everything will reinstall fresh.
Basically all you need is the favourites.txt file. |
Posted: Fri Jul 01, 2005 3:03 pm Post subject: Re: Poi and Medion 95900 |
Hooloovoo wrote: | The only thing you need to back up are the favoruites.txt file which contains all your saved locations, and the contents of your routes directory which contains any multiple-destination routes that you've saved.
Thanks for that Hooloovoo, it's good info to know.
Waffty. |
Posted: Fri Jul 01, 2005 3:56 pm Post subject: |
You will find though that the favourites.txt file remains in memory, even after a hard reset! _________________ TomTom Via 135 |
