Pocket GPS World :: View topic - problems connecting a polstar PBT-111 Bluetooth GPS & 39
MR_WHITE
PostPosted: Sat Jun 11, 2005 1:13 pm    Post subject: problems connecting a polstar PBT-111 Bluetooth GPS & 39 Reply with quote
I'm having problems connecting a polstar PBT-111 Bluetooth GPS receiver to my iPAQ 3970 running Pocket PC 2002 with Tomtom 5. Can anybody point me in the right direction, to what I need to do. And now to set it up
MR_WHITE
PostPosted: Sun Jun 12, 2005 4:14 pm    Post subject: Reply with quote
anyone??? it all works ok with tomtom 3.07 and also tomtom 4.44
but not with tomtom 5!
Taffman
PostPosted: Mon Aug 22, 2005 11:06 am    Post subject: Reply with quote
I also have a problem in connecting my Polstar X-70 which is think is simular if not the same as the PBT-111?
I can establish Bluetooth connection to my iPAQ h4150 running TomTom 5, but TomTom reports no GPS device?
After a while I lose bluetooth connectivity (blue light starts to flash on the X-70) If I look at connection status I see it connected, but no data sent or received.
The instructions for the X-70 do not state any paring procedure however the instrucions for the PBT-111 shows that it should be pared. I have tried it both pared and unpared with the same results.
Has anyone sucessfully managed to use a X-70 with TomTom 5, please let me know.
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
Taffman
PostPosted: Wed Aug 24, 2005 1:18 pm    Post subject: Reply with quote
See my Post at:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&p=140326#140326
for a possable fix for this.
mas
PostPosted: Fri Aug 26, 2005 11:14 am    Post subject: Reply with quote
i just got my nokia 6680 bt gps and tom tom 5
i had terriblt trouble as it wouldnt take the 0000 code to pair. eventually after turning both devices off and on it did ?
Then, and here's the bit for you , it just kept saying no gps signal.
What i did and it definately solved it for me was to go in to the tom tom menu select tom tom gps then re select ' other gps' and this kicked it in instantly.
Obviously it needed you to actually manually re select other gps on the menu even though ' other gps ' was shown as selected
hope it works for you.
Mas
Taffman
PostPosted: Fri Aug 26, 2005 12:17 pm    Post subject: Reply with quote
Hi Mas,
I have actually managed to fix this for my h4150 in the following way:
Go into GPS Device configuration in Tom Tom, then select "Other Cable NMEA GPS" (even though you are using a Bluetooth GPS receiver)!
Then select baud rate set to 4800
Finally select your Com Port, in the case of my HP 4150, COM Port 6.
Weird, but it works :-)
Thanks again for the help..
22.105 (30 Oct 24)
