Pocket GPS World :: View topic - TT5 - working but sat fix bars are blank ?
jase555
PostPosted: Sun Jun 12, 2005 10:52 am    Post subject: TT5 - working but sat fix bars are blank ? Reply with quote
just got tt5 up and running on my mio 168 clone,
seems ok apart from on tt3 i had a sat number and the bar was fully blocked,
but on the new version no no. of sats and no blocks lit up but it does work
any ideas
thanks
jase
PostPosted: Sun Jun 12, 2005 5:20 pm    Post subject: Reply with quote
maybe you have reprogrammed the receiver and now the GSV sequence is not sent any more?
Tewy
PostPosted: Sun Jun 12, 2005 9:02 pm    Post subject: Reply with quote
Lutz,
What does this mean, my son has a Medion MD9500 (clone of Mio 168) and has the same problem - GPS works fine but doesnt show any satellites being received. I have the same software TTN5) on my Mio 168 and it shows number of satellites etc. I am confused by this.
Ian
kitkitnet
PostPosted: Mon Jun 13, 2005 4:50 pm    Post subject: Reply with quote
I have the same problem, just received the TomTom Navigator 5 upgrade today, and install it right way in my iPAQ 3630.
I'm using original TomTom wired GPS (black in colour, Leadtek 9531/or 32?). TT5 can find my location but the satellites bar also shows nothing. I tried to run Leaktek's Navigator to check the Sat status and weird enough, it too can't show any Sat info now!
It was fine before I update to TT3 this morning! Any idea? Question
Robin2
PostPosted: Mon Jun 13, 2005 5:24 pm    Post subject: Reply with quote
TT5 doesn't show the number of satellites, but it should show a block like the signal strength indicator on a mobile phone. Presumably you can still view the satellite status by clicking on GPS to see how many satellites have been acquired. (I can't check because mine - ordered on June 1 - still hasn't left the warehouse grrrrr)
Robin
kitkitnet
PostPosted: Mon Jun 13, 2005 5:34 pm    Post subject: Reply with quote
Yes, I know, but that "signal bar" area is showing empty blocks, I even clicked into the TomTom GPS status area and found no info about individual Sat (Sat number, each Sat signal strength.. etc etc), the TomTom GPS status screen only shows the location and speed.
Mearns
PostPosted: Mon Jun 13, 2005 6:58 pm    Post subject: Reply with quote
I have a similar bug with TTN5.0 on my 2210 with Globalsat SD-501. It’s all working fine but as I type this the status summary page (not the signal indicator) shows 2 satellites being received when the GPS Status Page shows 7 satellites being received with 7 red bars. If I then go into any of the three Main Menu pages, in the bottom left corner it says “No valid GPS signal!” – yet everything is working perfectly!!
Tony
nuvi 2460LT plus Brodit mount
wadialdoor
PostPosted: Mon Jun 13, 2005 7:58 pm    Post subject: Reply with quote
I have the same problem the status summary page shows 2 or 3 satellites but the gps page shows more satellites
other problem is some point of interest like petrol station,hospital,restaurant,post office,open parking,nightlife,beach,car repair,cash dispenser,college/uni,company,golf course,mountain pass
all these point of interest which come as standerd on the map when you want to navigate to onr of them it says no POI found
but when select them to be showing on the map they do show
am i doing something wrong or ist normal???
never had this problme with tt3
PostPosted: Tue Jun 14, 2005 12:10 am    Post subject: Reply with quote
Can you all confirm that GSV is being sent? If not then navigation will still work but the number of sats in view (SV) will not be shown, giving he results that you see
Mearns
PostPosted: Tue Jun 14, 2005 9:55 am    Post subject: Reply with quote
Lutz - lost me there! What is GSV?
Tony
Mearns
PostPosted: Tue Jun 14, 2005 10:19 am    Post subject: Reply with quote
Ah, think I've found what you mean - the $GPGSV string. The SD-501 comes with a program called GPS Info. This only seems to be able to be run when TTN (either version 3 or 5) is not running. When this is so then the GSV information is being received and the number of satellites received is shown within the GPS Info program.
To get TTN to run (either version 3 or version 5) the GPS Info program has to be inactive or else nothing happens with satellite reception in the TTN program. Similarly if you try to start the Globalsat GPS Info program once TTN is running then nothing happens - GPS Info opens but will not run.
Having said all that, the others who are reporting this problem do not have the SD-501 and the common denominator seems to be TTN version 5.
Tony
PostPosted: Tue Jun 14, 2005 1:41 pm    Post subject: Reply with quote
My guess is that TTN5 is parsing the GSV string differently. It's well possible that different NMEA versions construct this string slightly differently (like, adding a data valid flag) , TTN5 expects the latest version of the string format and falls over when it meets older versions.
Just a wild guess.
PostPosted: Tue Jun 14, 2005 2:07 pm    Post subject: Reply with quote
Just tested it and it may actually be GSA, not GSV
Working:
Code:
$GPGSA,A,3,02,04,,08,,13,16,,23,24,27,,2.0,1.2,1.6*3D
$GPGSV,3,1,11,02,49,286,49,04,51,207,43,06,05,340,33,08,19,181,41*7E
$GPGSV,3,2,11,10,22,294,37,13,71,060,50,16,11,045,45,20,08,112,00*7A
$GPGSV,3,3,11,23,36,064,49,24,19,169,37,27,46,158,48*41
Not working:
Code:
$GPGSA,A,3,04,13,02,27,24,10,,,,,,,3.0,1.9,2.3*3E
$GPGSV,3,1,10,13,72,060,40,04,51,206,38,02,48,286,36,27,45,158,39*75
$GPGSV,3,2,10,23,37,064,00,10,20,292,37,24,20,169,30,08,17,180,00*7E
$GPGSV,3,3,10,16,11,046,00,20,08,112,00*75
Note how in the second version the GSA sats are lumped together whereas in the first example they appear in the same order as in the GSV strings.
laserdisc
PostPosted: Thu Jun 16, 2005 9:49 pm    Post subject: Reply with quote
I've got a Medion PPC250 and a RoyalTek RGM2000 GPS wired Receiver and my signal indicator bars do not work.
This seems to be a very common problem for PDA which are not listed on the TTN5 compatibility list.
I_Need_Help
PostPosted: Fri Jun 17, 2005 9:53 pm    Post subject: Reply with quote
Same problem
BC307 TTN5
although I do get some bars some of the time but often no bars but navigation continues OK
Just replaced my BC307 with Leadtek BT LR9537 this seems OK.
22.055 (29 May 24)
