Pocket GPS World :: View topic - Spoken POI alerts for TomTom GO, Mobile, PocketPC and Palm
Goto page Previous  1, 2, 3 ... 15, 16, 17 ... 71, 72, 73  Next
PostPosted: Thu Jun 02, 2005 8:24 pm    Post subject: Reply with quote
uhm, no... what did you use, babelfish?
Satisfying everybody is an art that nobody has mastered yet.
gingernut777
PostPosted: Fri Jun 03, 2005 5:08 am    Post subject: Reply with quote
Goes to show,, you can't trust he online translators.
I used "World Lingo" and got,
An art is done to each right, the nobody can
Using an A to Z
Sextant & Compass
cdelecole
PostPosted: Fri Jun 03, 2005 8:33 pm    Post subject: Reply with quote
I've tried the code psoted in this forum, to try generating my own sounds for POI alreting.
I'm using application 5.100 (5158/050510) SE:832
My chk file (5158.data.chk) is in C:\TomTom
My ogg files are under C:\TomTom\UKVoices
The VB code I'm using is the following :
Sub data_chk_reload()
Dim g As Long
Dim b As Byte
Dim bt As Byte
Dim Maxfiles
Maxfiles = 30
'this folder holds the original data.chk file N.B. Following line modified by TomTomTim
folder = "C:\TomTom\"
'identifier of the data.chk version. complete file name is identifier.data.chk
fname = "5158"
'the OGG files need to be in the subfolder specified by cell C1
fnum = FreeFile
Open folder & fname & ".data.chk" For Binary Access Read As #fnum
flen = FileLen(folder & fname & ".data.chk")
g = get_long
Debug.Print fname; " Number of modules: "; g; " File size: "; flen
'If (g <> 102) And (g <> 120) And (g <> 123) And (g <> 136) Then
'a = MsgBox("Not a good DATA.CHK file. Please report your build version of the TomTom program to lutz@pocketgpsworld.com", vbOKCancel, "Error - wrong file version")
'Close
'Exit Sub
'End If
'get offsets
If g = 102 Then Maxfiles = 12
ReDim entry(g + 1)
For i = 1 To g + 1
entry(i).offset = get_long
entry(i).sourceoffset = entry(i).offset
If i > 1 Then entry(i - 1).length = entry(i).offset - entry(i - 1).offset
Next
'confirm file size
If entry(g + 1).offset = flen Then
Debug.Print "File size confirmed"
Else
Debug.Print "File size mismatch! Reported:" & Hex(entry(g + 1).offset) & " Actual:" & flen
End If
'calculating new offsets etc
Debug.Print "Calculating new parameters"
i = 2
For f = g - Maxfiles To g
If (Cells(i, 3) > vbNullString) And (f < g) Then 'new file
Debug.Print "Verifying "; Cells(i, 3)
Debug.Print folder
Debug.Print Cells(1, 3)
Debug.Print Cells(i, 3)
flen = FileLen(folder & Cells(1, 3) & "\" & Cells(i, 3))
entry(f).ogglength = flen
pad = 0
While flen Mod 4 <> 0
flen = flen + 1
pad = pad + 1
Wend
entry(f).blocks = (flen + 12) / 4
entry(f).length = flen + 16
End If
i = i + 1
Next
'recalculate header
Debug.Print "Recalculating header ";
For i = g - Maxfiles To g + 1
entry(i).offset = entry(i - 1).offset + entry(i - 1).length
Next
Debug.Print "- new File Size is "; entry(g + 1).offset
'write output file
Debug.Print "Writing CHK file "
On Error Resume Next
Kill folder & Cells(1, 3) & "\" & fname & "_new.data.chk"
On Error GoTo 0
fnum2 = FreeFile
Open folder & Cells(1, 3) & "\" & fname & "_new.data.chk" For Binary Access Write As #fnum2
'write header
'number of segments
put_long (g)
'offsets
For i = 1 To g + 1
put_long (entry(i).offset)
Next
'non-voice files
'position pointer
Get #fnum, entry(1).offset, b
h = entry(g - Maxfiles).offset - entry(1).offset
For i = 1 To h
Get #fnum, , b
Put #fnum2, , b
DoEvents
Next
'write sound files, either from source or from new OGG
Debug.Print "Writing CHK file - Sounds"
i = 2
If (Cells(i, 3) > vbNullString) And (f < g) Then 'read new file
Debug.Print "Including "; Cells(i, 3); " for "; Cells(i, 1)
'recreate header
b = 1
Put #fnum2, , b
b = 0
Put #fnum2, , b
b = entry(f).blocks \ 256
Put #fnum2, , b
b = entry(f).blocks And 255
Put #fnum2, , b
put_long (1)
put_long (8)
put_long (entry(f).ogglength)
fout = FreeFile
Open folder & Cells(1, 3) & "\" & Cells(i, 3) For Binary Access Read As #fout
For h = 1 To entry(f).ogglength
Get #fout, , b
Put #fnum2, , b
DoEvents
Next
'padding
b = 0
flen = entry(f).ogglength
Put #fnum2, , b
flen = flen + 1
Wend
Close (fout)
Else 'read from source
'position pointer
Get #fnum, entry(f).sourceoffset, b
For h = 1 To entry(f).length
Get #fnum, , b
Put #fnum2, , b
DoEvents
Next
End If
i = i + 1
Next
Close
Beep
MsgBox ("Done - real new file size is " & FileLen(folder & Cells(1, 3) & "\" & fname & "_new.data.chk"))
End Sub
'required because of the little endian storage of long values
Function get_long() As Long
Dim b As Byte
l = 0
For h = 1 To 4
Get #fnum, , b
l = l * 256 + b
Next
get_long = l
End Function
Sub put_long(ByVal l As Long)
Dim b(4) As Byte
For h = 1 To 4
b(h) = l And 255
l = l \ 256
Next
For h = 4 To 1 Step -1
Put #fnum2, , b(h)
Next
End Sub
Private Sub CommandButton1_Click()
data_chk_reload
End Sub
The Excel sheet I'm using (For TOMTOM GO) is the following, since I only wants to change the Cow sound to radar1.ogg (Please note
the first line here below is at C1, D1, E1
the second line with Cow is at C12, D12, E12 :
UKVoices Sampling UKVoices
Cow 22050 radar1.ogg
When launching the macro, I'm getting the follwowing error :
Runtime Error at line :
I've added the following debug lines just before the faulty line :
Debug.Print folder
Those 3 debug lines are correctly giving me values "C:\TomTom\", "UKVoices" and "Cow"
But I'm wondering if instead of putting "Cow" at line C12, I should not put my ogg file ?!?
This has been reported nowhere, and I'm a bit condufed now.
Could someone give me some direction ?
Many thanks !
PostPosted: Fri Jun 03, 2005 8:57 pm    Post subject: Reply with quote
yes, that should contain the name of the source ogg file.
cdelecole
PostPosted: Fri Jun 03, 2005 9:04 pm    Post subject: Reply with quote
Just put my ogg file in Cell C12 ...
But now getting another error :
Runtime Error '9'
Subscript Out of range
into the section below :
i = 2
Debug.Print folder
pad = 0
flen = flen + 1
pad = pad + 1
The faulty line is :
Any clue ?
PostPosted: Fri Jun 03, 2005 9:13 pm    Post subject: Reply with quote
debug.print (folder & Cells(1, 3) & "\" & Cells(i, 3))
probably the file is missing
cdelecole
PostPosted: Fri Jun 03, 2005 9:24 pm    Post subject: Reply with quote
I've added the debug line ...
But how should I use the debug ?
What I'm doing is :
- Launch the macro
- Getting the Error message, and clicking DEBUG
- That is bringing me to the VB code, where I added the debug line
Putting the mouse on the words "Folder" and "Cells", I'm getting correct values : "C:\TomTom\", "UKVoices" and "radar1.ogg"
Seems correct, since my patch on my PC is :
C:\TomTom\UKVoices\radar1.ogg
PostPosted: Fri Jun 03, 2005 9:30 pm    Post subject: Reply with quote
is the file still open in a wave editor or media player?
cdelecole
PostPosted: Fri Jun 03, 2005 9:33 pm    Post subject: Reply with quote
No, not at all.
I also did the following :
Debug.Print flen
And the debug is giving me value "16086" for flen.
Not sure what the problem is ...
Is there any chance you can look at the Excel sheet ?
Maybe idiot problem ?
cdelecole
PostPosted: Sat Jun 04, 2005 9:15 am    Post subject: Reply with quote
Does anyone have a working Excel sheet with Lutz's code working to build a data.chk file for a TT GO 5.1 ?
I've tried pasting and following instructions from TomTomtim, changing some things like the version control or number of modukes control (With the help of Lutz), but with no success (See latest error message I got on my previous reply ...
Many Thanks !
cdelecole
PostPosted: Sat Jun 04, 2005 9:37 am    Post subject: Reply with quote
P.S. : You can send it to cdelecole@lucent.com
rayflan
PostPosted: Sat Jun 04, 2005 1:07 pm    Post subject: Reply with quote
cdelecole
Check your mail, sent you one
Ray
New Url www.tomtomsatnav.info
Visit my site
cdelecole
PostPosted: Sat Jun 04, 2005 7:05 pm    Post subject: Reply with quote
Ray, Lutz
Still getting ther same Runtime error"9"
Subscript out of range ...
I sent you my data.chk and ogg file back by mail, and put Lutz on copy.
I think there is an idiot thing somewhere I'm forgetting ...
Many Thanks !
rayflan
PostPosted: Sat Jun 04, 2005 9:11 pm    Post subject: Reply with quote
Problem is your data.chk file its 0kb
Ray
Visit my site
MarvintheRobot
PostPosted: Sat Jun 04, 2005 11:37 pm    Post subject: Reply with quote
Can Any One help me with this one
I need a data.chk file thats got these in...
1 "BLEEP BLEEP" Gatso 30
2 "BLEEP BLEEP" Gatso 40
3 "BLEEP BLEEP" Gatso 50
4 "BLEEP BLEEP" Gatso 60
5 "BLEEP BLEEP" Gatso 70
6 "BLEEP BLEEP" Mobile 30
8 "BLEEP BLEEP" Mobile 40
9 "BLEEP BLEEP" Mobile 50
10 "BLEEP BLEEP" Mobile 60
11 "BLEEP BLEEP" Mobile 70
12 "BLEEP BLEEP" Red Light
13 "BLEEP BLEEP" Specs
14 "BLEEP BLEEP" Temporary
15 Credits
I like the "BLEEP BLEEP" it stands out over what ever I'm listening to on the radio
Chris
MarvintheRobot
Tom Tom Go 300
App 5.000 (4109/050407) OS:723
GPS v1.21, Boot 2.04
Map: Great_Britain-Map' v562
512 SD Card
curently using 5158_new.data.chk
Page 16 of 73
22.055 (29 May 24)
