Pocket GPS World :: View topic - Mio 168 battery level indicator
turp
PostPosted: Thu Jun 02, 2005 2:16 pm    Post subject: Mio 168 battery level indicator Reply with quote
Hello all i have just bought a mio 168 going well just i would like to have the battery indicator on the screen in the bottom right hand side i have gone to start-settings-system-power there is no box to tick to place the indictaor on the desktop any ideas Cheers Paul
Pocketgps
PostPosted: Thu Jun 02, 2005 3:06 pm    Post subject: Reply with quote
There is a battery monitor on my web site, just click the link at the bottom of this post, then look down the Specs page.
Works fine with the Mio168.
turp
PostPosted: Thu Jun 02, 2005 4:10 pm    Post subject: Reply with quote
Thanks very much for that i have downloaded it and run it its in the pda main memory but not showing up ??? any ideas sorry to be sounding a bit thick
PAul
turp
PostPosted: Thu Jun 02, 2005 4:11 pm    Post subject: Reply with quote
i knew it would happen as soon as i posted that previous post its there in the desktop
many thanks for that
Paul
polekat
PostPosted: Tue Sep 13, 2005 11:18 am    Post subject: Reply with quote
would this work with the my guide navigator 6500 xl (another mio clone)
running windows mobile se
thanks
polekat
Pocketgps
PostPosted: Tue Sep 13, 2005 3:30 pm    Post subject: Reply with quote
polekat wrote:
would this work with the my guide navigator 6500 xl (another mio clone) running windows mobile se
thanks polekat
Yes it should work OK, after you install it you may need to do a SOFT re-set to get it to show.
polekat
PostPosted: Tue Sep 13, 2005 8:34 pm    Post subject: Reply with quote
Thanks pocketgps it works just fine :D ,very good site i've used your site quite a few times over the past year or so, very informative when i was trying to get poi warner to work with the speed cams.
Keep up the good work for all us novices out there we appreciate it.
thanks again
polekat
LiveLifeGoJump
PostPosted: Fri Sep 16, 2005 12:03 pm    Post subject: Reply with quote
The battery monitor could be useful when walking using Memory Map etc. so I've downloaded it to try. You have other utilities on your site, any chance of adding a 'screen blanker' utility for the ppc that would put an icon on the screen which, when tapped, would blank the screen (requiring a short press on the power button to reactivate) while leaving the program running (as per the screen toggle function in mp3player, Windows op.sys.)?
I know that this facility extends battery life but it is a pain switching back & forth between MM & mp3player.
I'd be willing to buy a utility like that as long & it didn't cost to much>
If riding in a plane is flying then riding in a boat is swimming. If you want to experience the feeling
GET OUT OF THE VEHICLE
Sequin
PostPosted: Fri Sep 16, 2005 1:20 pm    Post subject: Reply with quote
There are lots of free programs available on www.freewareppc.com - including many battery monitors - look in the Utilities section under Enhancements
There are also timeout programs that will automatically shut down your PPC - I haven't checked out all that is available, but there are lots of goodies there
Sequin
PostPosted: Fri Sep 16, 2005 1:27 pm    Post subject: Reply with quote
Some candidates:
http://www.freewareppc.com/utilities/displayoff.shtml
http://www.freewareppc.com/utilities/noscreen.shtml
http://www.freewareppc.com/utilities/screenswitch.shtml
http://www.freewareppc.com/utilities/screenoffforpocketpc.shtml
LiveLifeGoJump
PostPosted: Fri Sep 16, 2005 3:12 pm    Post subject: Reply with quote
Thanks a lot for that, downloaded Displayoff (first link) & it works well (except TTN5 which I sometimes use when a passenger & have no access to power socket).
LiveLifeGoJump
PostPosted: Mon Sep 19, 2005 10:25 am    Post subject: Reply with quote
Battery life extended by at least 25% using Displayoff.
Thanks for the link Sequin
LeighB
PostPosted: Tue Sep 20, 2005 1:27 pm    Post subject: Reply with quote
I have downloaded Displayoff, and it seems to work OK, using a button to operate it, and the record button to switch the display back on.
Only slight snag is that when I switch back on, it also activates the "Notes" program, and I then have to switch back to Memory-Map to see where I am.
Is there any way to avoid Notes being activated?
Leigh
Mio168 Kingston 256SD
TomTomNavigator3 3.07
TomTom Navigator 5
Memory Map 2004 OS 4.4
Checkpoint 2.02
LiveLifeGoJump
PostPosted: Tue Sep 20, 2005 3:13 pm    Post subject: Reply with quote
I have disables all the buttons (Start, settings,buttons/select none for each.) then programmed button 5 (record button) to run Display off. This is because I often carry the ppc in a shirt pocket & the front buttons get pressed by accident.
The ppc can then be put into display off mode by a brief press on the record button & display can be reactivated by a brief press on the power button. The ppc will then display the program you were last using (it works with any program EXCEPT TTN5). If you were using Memory Map then Memory Map will be displayed on reactivation showing the current location (assuming you have locked gps position to centre of screen with the lock icon).
What may be happing for you is that one of the front buttons is allocated to notes & is being pressed by accident.
Norman
LeighB
PostPosted: Tue Sep 20, 2005 3:20 pm    Post subject: Reply with quote
Norman,
Thanks I will try that and see how it goes
Leigh
TomTom Navigator 5
Checkpoint 2.02
22.062 (12 Jun 24)
