Pocket GPS World :: View topic - destinator and memory cards
cyclopops
PostPosted: Fri May 06, 2005 8:51 am    Post subject: destinator and memory cards Reply with quote
im thinking of buying a bigger card (512mb) so i have more room for other stuff and destinator on the same card to avoid having to keep inserting different cards for different stuff, can this be done? and how do i go about putting destinator on there
PostPosted: Fri May 06, 2005 9:03 pm    Post subject: Reply with quote
According to my tests the older versions of Destinator (up to 3.0.75) cannot completely be put onto memory card. This seems to have changed with the newer versions - PN and LT etc. But I'm not sure when those will be out.
However, you can certainly have the Destinator maps and your other stuff on the memory card to avoid card swapping. 512 MB may not be big enough though... "There is no such thing as free space on a storage card"... 8O
cyclopops
PostPosted: Fri May 06, 2005 9:23 pm    Post subject: Reply with quote
thing is i read somewhere that there are problems with 1gb cards is this the case or not?
i have an acer n35 if that makes a difference or not?
PostPosted: Fri May 06, 2005 9:41 pm    Post subject: Reply with quote
You probably have read about problems with SanDisk China cards. If you chose a good brand then there's no issue.
cyclopops
PostPosted: Fri May 06, 2005 9:44 pm    Post subject: Reply with quote
ok thanks Smile
cyclopops
PostPosted: Sat May 07, 2005 8:23 am    Post subject: Reply with quote
one more wuestions for you
how exactly do i go about getting all my info onto the new memory card?
i dont have a card reader but maybe able to borrow one (hopefully if his is one of those fancy multi card readers)
or can it be done without a card reader?
h5djr
PostPosted: Sat May 07, 2005 1:08 pm    Post subject: Reply with quote
It can be done without a card reader using MS ActiveSync but each map will take in the region of 40-50mins to copy across.
If you can get access to a card reader the maps only take about a minute to copy.
Dave R
cyclopops
PostPosted: Sat May 07, 2005 8:23 pm    Post subject: Reply with quote
but what is it i need to do? (its my first PDA so am unaware what to do)
cheers for the help by the way
ReZ
PostPosted: Thu May 19, 2005 8:39 pm    Post subject: Reply with quote
im building myself up to buying one of these
WiFi + 256Mb
Hope it works if i get it...
if it does i'll let you know...
in fact nah...... you go 1st Smile
/ReZ
Wireless would be handy tho tbh + also could just copy the destinator maps straight on no worries...
ReZ
PostPosted: Thu May 19, 2005 8:41 pm    Post subject: Reply with quote
they do bulk orders if enough people are up for it...
send me your money ... Laughing Out Loud?
/ReZ
ReZ
PostPosted: Thu May 19, 2005 9:30 pm    Post subject: Reply with quote
and cyclops ..
open file explorer
click on My Device at the top
then click on DestinatorApps
then click and hold on Destinator and select copy
then click on My Device at the top again
then click on SD-MMC Card
then find a bit of space near the bottom of the screen, click on it and hold it... select paste.
This will copy all stuff onto ur sd card, what use that is i'm not sure; i'm hoping i will be able to KEEP my favourites if i have to hard reset.
The other day while running D3 and several trial today progs (i'm new) it decided to hang with the screen on... and i couldn't soft reset. So i let the battery run out hoping i would be ok... i wasn't, i lost all my lovely favourites... bugga
Hoep this will sort it... as the auto back up did naff all :/
/ReZ
ReZ
PostPosted: Thu May 19, 2005 9:34 pm    Post subject: Reply with quote
hope u dont think im spammin'
SPAM SPAM SPAM SPAM!!! 8O
btw i'm assuming you have an acer n35 gps btw Rolling Eyes
I guess the procedure would be similar?
:good luck:
/ReZ
22.105 (30 Oct 24)
