Wishlist Lifetime Member
![](modules/Forums/images/avatars/171190217745ad5a1683203.jpg)
Posted: Sat May 14, 2005 11:36 pm Post subject: |
alix776 wrote: | wishlist how do you mean the post codes dont work could give me more info please as my freinds go 300's postcodes work fine | We were talking about the Classic not the 300. And they do and will work on both with the "file" that this thread is talking about. :P |
ChrisCubed Occasional Visitor
Posted: Mon May 16, 2005 9:26 am Post subject: |
I'm awaiting the inevitable i.e. this 'Great_Britain.Postal' file hitting the net. |
jeffblockley Occasional Visitor
Posted: Mon May 16, 2005 5:46 pm Post subject: |
Do not buy the map update there is no update in the maps only the full postcodes there are roads in Glasgow that have been there for 3 yrs are still missing. |
alix776 Pocket GPS Moderator
![](modules/Forums/images/avatars/6212487444319be6786243.jpg)
Posted: Mon May 16, 2005 8:06 pm Post subject: |
jeff have you read mikes response about map data earlier int he thread _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
FazerBoy Occasional Visitor
Posted: Tue May 17, 2005 6:22 am Post subject: |
Should someone be lucky enough to acquire this 'Great_Britain.Postal' file, where does it go or what does it replace on the v5 TTG?
Just interested, thats all!!
Fazerboy |
Tim Buxton Pocket GPS Moderator
![](modules/Forums/images/avatars/483587116439494e7a5e13.jpg)
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Tue May 17, 2005 6:36 am Post subject: |
Naturally it would go where it was installed by the TTN5 map/data installation programme. ![Joker](modules/Forums/images/smiles/custom8.gif) _________________ Tim |
Posted: Tue May 17, 2005 8:23 am Post subject: |
Should you be lucky enough, I believe it needs to go in a folder named 'zip' in the root directory of the TTG. |
Posted: Tue May 17, 2005 5:56 pm Post subject: |
Chris,
I don't seem to have a folder named 'zip'.
I only have two folders showing on my PC thought the SD card. One named 'Great_Britian Navigator Map' which contains the ov2 files and one named 'itn' which contains a temporary itn file.
Where is this 'zip' folder?
Just interested to know!
Cheers |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Tue May 17, 2005 6:55 pm Post subject: |
FazerBoy wrote: | Chris,
Cheers |
You won't have it unless you have the 'upgraded' maps. _________________ Richard
rkm_hm Frequent Visitor
![](modules/Forums/images/avatars/gallery/web.jpg)
Joined: Nov 28, 2004 Posts: 532 Location: Warwick, UK
Posted: Tue May 17, 2005 7:02 pm Post subject: |
FazerBoy wrote: | Where is this 'zip' folder? |
It gets created automatically when you install the updated map.
However, there's nothing stopping you from creating a 'zip' folder yourself if you wish. |
Posted: Tue May 17, 2005 11:15 pm Post subject: |
rkm
Not sure how to do that!
As you can gather, my technical knowledge is limited.
Is it easy? |
Posted: Wed May 18, 2005 12:21 am Post subject: |
FazerBoy wrote: | rkm
Is it easy? |
With TTG connected to a USB port on your computer, it behaves just like an external disk drive. You can create folders on it by selecting it in Windows Explorer and then using the File/New/Folder menu. |
Posted: Wed May 18, 2005 9:16 am Post subject: |
Is it easy? |
Since 'acquiring' and using the Postcode zipfile would be illegal by any means other than purchasing it, does it really matter how easy it might be? You are treading on dangerous ground here guys.... ![Grrrr](modules/Forums/images/smiles/grr.gif) _________________ Tim |
Gus607 Occasional Visitor
Posted: Thu May 19, 2005 6:59 pm Post subject: |
Just installed the "ZIP" file from my new SD card to my old card & works fine, although I had to delete a few unwanted voices to make space. The file is 8+ meg and will fit on a 128meg card. |
BanziBarn Regular Visitor
Posted: Fri May 20, 2005 3:03 pm Post subject: |
Does it work? |
