plexy Occasional Visitor
Joined: Aug 17, 2004 Posts: 14 Location: Hampshire uk
Posted: Mon May 16, 2005 11:37 pm Post subject: ipaq 3970 ppc2003 downgrade to ppc2002 help needed |
as header..........need to downgrade so i can use my navman gps jacket (not supported with ppc2003 upgrades)
as i understand it, this was upgraded with the official hp rom version 4.00.08ENG (by the previous owner) using a cdrom that i don't have.
from my research here, it is possible to downgrade to the ppc2002 rom 2.10.
my question is .....can i download the software/can someone send it to me/can someone give me an idiot proof guide/instruction.
thanks to all who reply ![Exclamation](modules/Forums/images/smiles/icon_exclaim.gif) |
lbendlin Pocket GPS Staff
![](https://www.pocketgpsworld.com/modules/Forums/images/Caricature-Lutz.png)
amcluesent Regular Visitor
![](modules/Forums/images/avatars/gallery/052.gif)
Posted: Tue May 17, 2005 11:13 pm Post subject: |
>need to downgrade so i can use my navman gps jacket<
Are you sure? I flashed a 3970 to the 4.00.08ENG ROM to get version 4.20 of WM2003, installed the Navman 3.1.6 driver and TomTom3 is working fine with the Navman SE sleeve. |
Posted: Wed May 18, 2005 12:22 am Post subject: |
thanks so far.
amcluesent.......thats strange :o , i tried some time back & it did not work. i contacted navman uk & they said it is not supported with an upgraded ppc2003 O/S.
any tips for me to try / instructions / links?
thanks. |
clivers Regular Visitor
Joined: 03/07/2003 09:14:39 Posts: 185 Location: Portsmouth, Hampshire, UK.
Posted: Wed May 18, 2005 12:19 pm Post subject: |
my navman sleeve works with WM2003
i had to install the navman software and then update it through the update routine that they have.
i dont use the navman software but have it on just to run the sleeve. worls ok with tomtom _________________ Ipaq 3970, Ipaq 2210 X2, Smart ST V1, Tomtom V3+V5, CoPilot V5, AA Navigator, Tomtom Bluetooth GPS, Navman 3450i Jacket, Navman Bluetooth GPS, Holux GM270, Fortuna GPS-PocketXtrack
, Tomtom GO V5 Classic, Road Angel Classic. |
Posted: Wed May 18, 2005 5:12 pm Post subject: |
>any tips for me to try / instructions / links?<
I upgrade the 3970 using the standard HP WM2003 upgrade CD. The Navman 3.1.6 serial driver and GPS Info 1.3 programs I downloaded from here. I'd also flash upgraded the sleeve's firmware using the latest version from the Navman site. This combination works OK with TomTom 3. I've never actually installed the Navman ST software itself. |
Posted: Sat May 21, 2005 4:05 pm Post subject: |
i connected the ipaq to the pc via the comms lead/active sync.
when i try to run the navman gps info or the gps firmware upgrade i get a message like
' 3.1.6 does not support connected device type'
this is what i got before......navman technical say its not compatable!
when i do a soft reset the compaq window shows a version 4.00.
i have not tried to load the smart explorer software.
any ideas/help anyone ![Question](modules/Forums/images/smiles/icon_question.gif) |
Posted: Mon May 23, 2005 9:46 pm Post subject: |
amcluesent,
how did you get the 4.20 version?.........do you think this may be my problem? |
Posted: Mon May 30, 2005 5:13 pm Post subject: |
>how did you get the 4.20 version?<
The ROM is 4.00.08ENG, the 'About' screen shows Windows Pocket PC 4.20.1081 (Build 131000).
After upgrading the iPAQ ROM, the 3.1.6 Navman serial driver was the first s/w I installed. I'm also using the Navman SE sleeve, with 2.3.7 firmware. I'd flashed the sleeve before upgrading the iPAQ ROM.
The Navman sleeve appears as COM7, 57600 baud in GPS Info 1.3 |
SuperBaka Occasional Visitor
Posted: Sat Jul 02, 2005 9:56 pm Post subject: |
i've just downgraded my 3970 from a "beta" 2003 to a 2.10 2002 .
1. dl the 2.10 rom
2. extrat the rom and open NK_Windsor21010WWE.nbf with an hex editor like ultraedit
you should see something like :
69 50 41 51 20 33 39 30 30 2D 57 42 54 2D 45 4E
47 2D 32 2E 31 30 2D 32 63 66 34 2D 2D 2D 2D 2D
FE 03 00 EA 00 00 00 00 00 00 00 00 00 00 00 00
remove :
the file must start with :
3.save the file and rename it in as a .nb0 .
4. use the same updater then for the "beta" rom and instead of typing
"lnb nb.nb0" type "lnb thenameofyourfile.nb0"
5.have faith in god and wait about an hour
6.it worked for me and i hope for you too .
if you still want to use this beta and use as well bt you can try to dl
the widcomm driver and then apply the hp bt patch (note you have to install both of them just after a hard reset else you 'll have great difficulties for installing it while the dll are in use ...)
i tried it several times myself but when bt was working i had some issue like each time you use the power buton you have to do a soft reset to boot it ...
i hope that it can help a few stupid guys like me and that my english was not too bad to be understood . |
W90BHP Occasional Visitor
![](modules/Forums/images/avatars/695314185512f241b887c5.jpg)
Posted: Thu Jul 07, 2005 8:43 pm Post subject: |
I downgraded my iPAQ 3970 back to 2002 easily using the version of 2.10 supplied on the upgrade cd.
My reason for downgrading is that the bluetooth manager within the 2003 upgrade (v4.0?) hung my 3970 everytime I tried to switch bluetooth on. Following an "active support" session online with HP involving a hard reset, everything worked OK until I reinstalled my software and appointments then the problem resurfaced. Anyone else have this problem?
Martin _________________ LG G4: Android 6 : Viewranger : CoPilot : Waze
TomTom Go 730T : Traffic subscription long expired
Nokia E61 : Nokia GPS : TomTom Navigator 6 : Retired from duty
iPAQ 3970 : Navman Sleeve : CoPilot 4 : Somewhere in the loft |
