Heyou Occasional Visitor
Joined: 10/09/2003 10:36:18 Posts: 38 Location: United Kingdom
Posted: Sat Apr 16, 2005 10:10 pm Post subject: Can you name this 9532 backup battery |
Anyone know what this batteries identity is??
It's on the underside of the circuit board, i didn't think there was battery at first it's so small, and it's what's causing my wired GPS to take forever to get it's first fix.
Description :-
The only things written on the battery are :-
on the side of it "0302"
on the positive face :- "IIS" and "made in Japan"
It may have more writing on it but it also has 2 circuit board solder tags spot welded to it, covering up any more info. I think, i've worked out that it's 3 volt?? by plugging in the charging unit and measuring the voltage coming from the battery whilst it's on the circuit board!! but of course i may completely wrong about this.
It never gets to above 2.2volts after being on the DC supply and remove the DC supply and it drops down to .6 volts within a few hours.
I've emailed Leadtek, no response, and i guess they won't tell me what the battery anyway, only that they'll repair the unit for a price!! I know i can fix this if only i could source a battery for it.
So what i'm after is - 3volt ? - 6.5mm Dia. X 1.5mm height.
I'm pretty sure it's rechargeable.
It has 2 solder tags on it but i won't hold my breath - i could modify it to solder it to the circuit board.
cheers
Del.
Here's the little critter :-
_________________ _________________ Good judgement comes from experience. Experience comes from bad judgement |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Tue Apr 19, 2005 7:03 pm Post subject: |
Thanks for the info.
About it not being a 3 volt cell. As i said i measured the voltage across the battery with the charger plugged and then charged it up over the course of 12 hours.
I then unplugged the charger and measuered the voltage and it never got above 2.2 volts. Now either way that way above 1.2 volts, if it's a 1.2 volt cell but comfortably below for a knackered battery top be a 2.4 volt cell.
So i wonder which way i should go??
thanks again
Del. _________________ Good judgement comes from experience. Experience comes from bad judgement |
Vic Occasional Visitor
Posted: Tue Apr 26, 2005 12:24 pm Post subject: |
Hi Del
I have a similar cell in my 9537 BT Gps and yes it is a 3v cell. http://www.smallbattery.company.org.uk/ Try these people, they're very helpful, quick and don't rip you off with postage.
Vic |
Posted: Tue Apr 26, 2005 1:41 pm Post subject: |
Hi Vic
Funnily enough, i emailed the Small Battery Company http://www.smallbattery.company.org.uk/ along a few others, and they were the only ones to reply. I'm speaking to a very helpful chap and he's trying to decide if it's a Lithium cell or not?
Do you know if it's a Lithium cell? i'm certain it's a rechargeable cell but what chemical makeup i don't know? nickel metal hydride or NiCad?
Did you manage to get a battery that worked for you and did you fit it?
cheers
Del _________________ Good judgement comes from experience. Experience comes from bad judgement |
Posted: Tue Apr 26, 2005 1:48 pm Post subject: |
I didn't need a battery as the problem was elsewhere (see my other threads on the 9537) however I did remove the cell on the pcb which looks very similar to yours with the same welded tags and checked it and it was definately 3volts.
Vic |
Posted: Tue Apr 26, 2005 4:41 pm Post subject: |
thanks, i'll go for anything tha's approx. the same size/rechargeable and 3 volts and see what happens. 8)
cheers
grahamwalker Regular Visitor
Posted: Fri Apr 14, 2006 10:10 pm Post subject: |
Did anyone ever manage to obtain a replacement 9532 battery? Mine took 15 mins when parked stationary at the side of a very wide road to get a fix this morning - its becoming a nightmare.
I assume that the backup battery won't help improve a cold-fix startup time, but at least it would keep its settings a bit better when I stop the car for a few minutes.... |
