Pocket GPS World :: View topic - PPC overlay (userdata.mmo) errors
DABurleigh
PostPosted: Mon May 10, 2004 4:05 pm    Post subject: PPC overlay (userdata.mmo) errors Reply with quote
I'll ask on here as MM support either doesn't respond or says wait-out and never gets back with an answer.
Everything works fine on both PC and PPC, except when I restart MM on the PPC having previously and successfully used a large overlay file on both the PPC and the PC (used to export to PPC).
Then my 3497k userdata.mmo file gets somehow pared back to around 3127k (it varies) and the original file gets backed up to old_userdata.mmo file at the correct size.
On re-running MM on the PPC I get:
"An attempt was made to access an unnamed file past its end" and:
"A sharing violation occurred while accessing \ProgramFiles\Memory-Map\OS\userdata.mmo".
Now if delete userdata.mmo and rename the old_userdata.mmo file to userdata.mmo, it works, until I close MM down and re-load, whereupon I get the same errors.
Driving me up the wall.
The file on the PPC originates from MM PC export, not me creating it.
Any ideas?
DABurleigh
PostPosted: Thu May 20, 2004 10:20 pm    Post subject: Reply with quote
At least I'm not the only one:
http://www.memory-map.co.uk/board/index.php?showtopic=94
Still silence from MM.
And my loss of proximity alarms since the upgrade has been acknowledged, but still not fixed.
Ho hum.
22.054 (22 May 24)
