Pocket GPS World :: View topic - Garmin 765 touch screen issue & switch off issue
letmeboogey
PostPosted: Mon Dec 29, 2008 2:34 pm    Post subject: Garmin 765 touch screen issue & switch off issue Reply with quote
Hi All
So far i have not noticed any switch off on my system. I have updated all the latest software and disabled (unticked) the 3d buildings by going to tools, settings, map and map info. I was told there will be a software update to resolve this issue soon. This is a stop gap measure.
For those that have had issues with with the touchscreen or typing, i appears you can calibrate the screen, which i have done and has improved things alot for me anyway. I spoke to garmin and told me switch off the unit keep a finger pressed in the centre screen, (may need a bit of hard press), then switch the unit on move the sliding switch to lock symbol it should then bring up a calibration screen for you press on a dot. Once completed it should have improved. This worked ok for me.
This may or may not work for you and carrying this out is at your own risk.
Feek
PostPosted: Mon Dec 29, 2008 8:43 pm    Post subject: Reply with quote
I agree with the screen calibration, my old 760 was a bit off but I coped with it as I knew how far and in which direction it was off, but my 765 did the same although to a different extent. I then googled to find the screen calibration routine that you've just described.
The trick is to turn the unit on and move the slider straight back to the lock position with no pause, literally finger on screen, slide left, slide right.
I also used a stylus to calibrate the screen rather than a sausage of a finger and it worked a lot better.
22.062 (12 Jun 24)
