Pocket GPS World :: View topic - Audio out
Audio out
UK2007
PostPosted: Tue May 01, 2007 12:03 am    Post subject: Audio out Reply with quote
Since updating topmtom 910 to the firmware when new FM mount came out,the audio out socket won't work.Ive tried headphones and my ebay transmitter but no sound out Sad
I also tried the normal none FM Mount But no sound out either!! Sad
Is there a setting i have clicked in the tomotom settings on screen Confused
PostPosted: Tue May 01, 2007 6:52 am    Post subject: Reply with quote
It should work fine with the audio out, can you try the following:
Change Preferences/ Speaker Preferences, answer No to the question about using the FM transmitter mount, then make sure that both of the following are ticked:
Play music over external speaker
and
Play spoken instructions ov external speaker
Check for sound using your headphones. If that is working put the device back on the FM Transmitter mount go to change preferences/ speaker preferences answer Yes to the Use FM Transmitter question, set a fequency and tune the radio in to listen to it - Mike
