zzr Occasional Visitor
![](modules/Forums/images/avatars/gallery/animal_bear.jpg)
Posted: Mon Jan 15, 2007 10:56 pm Post subject: hard wiring tomtom rider |
hi all,
could someone point me in the direction of some diagrams showing how to wire up the power cable for my rider please any help would be great
Tim |
ditchfinder Occasional Visitor
Posted: Sat Jan 20, 2007 11:09 pm Post subject: |
hi zzr just wire the neg to the chassis (frame, earth) & the positive to a ignition switched feed ( i used the side/parking lamp feed ) this means the cradle/mounting is only live with the key on hth 8) |
scarer Occasional Visitor
Posted: Fri Mar 16, 2007 5:51 pm Post subject: |
I just soldered some ring terminals to the cable ends and bolted directly on to the battery terminals, running the cable down the underside of the tank.
I always remove the gps from the bike so there shouldn't be any issues with running the battery down. |
Posted: Fri Mar 16, 2007 6:40 pm Post subject: |
scarer wrote: | I just soldered some ring terminals to the cable ends and bolted directly on to the battery terminals, running the cable down the underside of the tank. |
I hope you fitted a fuse to protect the wiring (5A inline will suffice) - direct feeds from the battery are not a good idea, if the cable is severed or rubs on the bikes structure due to vibration you could suffer an electrical fire! - not recomended, more so if its routed under the fuel tank - Mke |
Posted: Fri Mar 16, 2007 11:04 pm Post subject: |
Good job I've removed it then.
The Zumo comes with an in-line fuse already in the wiring so all should be good now...as did my heated waistcoat and heated gloves and heated grips. Wonder why tomtom don't go the extra mile? |
Posted: Sat Mar 17, 2007 12:05 am Post subject: |
scarer wrote: | Wonder why TomTom don't go the extra mile? |
Why do you need or want an extra mile when using a Sat Nav - most people want the most efficient route 8) .
In all seriousness though make sure any connection to the battery is suitably fused, I wouldn't want an electrical fire in car let alone on a bike - Mike |
AndyCr15 Regular Visitor
![](modules/Forums/images/avatars/gallery/simpsons6.jpg)
Posted: Wed Apr 11, 2007 1:43 pm Post subject: |
I just bought a Zumo 500. Are there any diagrams/pictures that might help me install the power to the ignition? I don't want to get it wrong and active the imobilser or anything. If it matters I have an 07 Honda Transalp. _________________ TomTom 6 - SPV M5000 and WM6
Garmin Zumo 500 on Honda TransAlp
www.lanarchy.co.uk for LAN gaming near London |
