Pocket GPS World :: View topic - POI's
POI's
richyscott
PostPosted: Mon Dec 26, 2005 3:50 pm    Post subject: POI's Reply with quote
I have just had a Garmin i3 for christmas, and I cannot seem to get the POI feature to work correctly?
I have downloaded the poi loader software from Garmin, and I have also loaded the speed camera function onto the i3, but none of the speed cameras show up on my map when I go driving around, or do a simulation (No other points of interests show up on my map either, such as bars, hotels, fuel stations etc..)?
I can find all of the speed cameras on my Garmin, using the "Where to?" function, but they just don't appear on the screen while driving?
Also, would somebody b able to tell me how, I get my Garmin to warn me of approaching speed camera's?
RODTROTTER
PostPosted: Mon Dec 26, 2005 11:33 pm    Post subject: Reply with quote
to check to see if you have loaded they right try this
1 turn on your i3
2 press where to
3 press food hotels and more
4 press custom points
5 scroll down all the way if yoiu have the speed cams on they will show right at the bottom of the list
if you see them pick one they press on it then click on show map and it should show you where the cam is on the map
and as for not showing on map when driving if you doing above the speed limit or just under it will tell you other pois will show if you pick them hope this helps
