Pocket GPS World :: View topic - Blaupunkt Travelpilot E1 - Constantly recalibrating?
Craig_F
PostPosted: Mon Aug 29, 2005 12:39 pm    Post subject: Blaupunkt Travelpilot E1 - Constantly recalibrating? Reply with quote
I recently bought a Blaupunkt Travelpilot E1.
However its not a unit I use every day, when I actually need to use the unit it reads my position as being incorrect, and tells me to turn well after I actually needed to.
After a bit of investigation it turns out I need to calibrate the unit every time I use it, as you can imagine this can get a bit frustrating!
Any ideas or is this the norm?
Thanks in advance
alix776
PostPosted: Mon Aug 29, 2005 12:42 pm    Post subject: Reply with quote
is the gps permanently connected to the battery like the raidio the receiver loseing it almanac might be the reason
device Lumia 950 xl
Craig_F
PostPosted: Mon Aug 29, 2005 1:15 pm    Post subject: Reply with quote
The unit is connected to the battery permenatly, and is also connected to the switched live. (ignition).
Might help you guys if I give you a bit of background Embarassed
Its a 1999 Renault laguna, with a speedo sense cable fitted from the factory.
I've added the blaupunkt as a second head unit, with connections to:
The battery
Switched live(ignition)
Ground
speedo sense
A speaker mounted near the fuse box as per the computer speaker fitted on higher models.
The GPS aerial
22.054 (22 May 24)
