Pocket GPS World :: View topic - Antenna
Antenna
mdilloway
PostPosted: Thu Sep 23, 2004 12:59 am    Post subject: Antenna Reply with quote
Does anyone know the pinout for the sapphire RGM-2000 antenna, the new small 5 pin connector.
Cheers.
lbendlin
PostPosted: Fri Sep 24, 2004 3:05 am    Post subject: Reply with quote
what are the wire colors?
You may also be able to figure it out the other way round, working from the PDA connector. What PDA do you use?
Only four wires are required, Ground, Power, RxD, TxD .
Lutz
TomTom/TeleAtlas NAVTEQ
mdilloway
PostPosted: Fri Sep 24, 2004 4:43 am    Post subject: Reply with quote
Thanks for the reply,
I use a Mitac 338, I haven't got the antenna just the PDA cable, I was hoping to use an Emtec antenna, but will obviously need to make up a cable. I tried to find out which pins on the socket had voltage but didn't seem like any (I know there must be) I then wondered if there had to be a load connected.
lbendlin
PostPosted: Fri Sep 24, 2004 5:01 am    Post subject: Reply with quote
see if this helps
http://www.expansys-usa.com/product.asp?code=112412
Lutz
mdilloway
PostPosted: Sun Sep 26, 2004 6:41 am    Post subject: Reply with quote
Thanks for the help,
I've ordered a sapphire antenna now, I didn't really want to pay over £100 but it should just work straight off without any messing about.
Cheers.
