Ferd32 Occasional Visitor
Posted: Wed Sep 08, 2004 2:56 pm Post subject: TT Postcode has F--ked My GPS |
Needless to say I am F--ked right OFF now.
I loaded TT GPS and TT sat nav this morring and then I loaded the speed camera add on as well. It all worked fine.
I then loaded the UK postcode update to the letter and when I went to start it I got an error message somethink like unable to find ukpostcode file or somthink.
Now the gps will not work (ipaq nav system with a Ipaq 3970) It will still see the CF card but no gps
Have tried unloading and loading it again and have even rebooted the PPC2002 OS and it just sits there not even looking for a signal.
Any help and you will be my best mate.
F--ked OFF Ferd32 |
Darren Frequent Visitor
Posted: Wed Sep 08, 2004 3:06 pm Post subject: |
It's highly unlikely to be the UKPostCode application. In all the thousands of installs I have never heard it causing any issue to TomTom Navigator.
Can you remove the jacket, soft reset then re-attach the jacket. Also what settings have you configured in the GPS Driver applet? _________________ Darren Griffin |
Joined: 30/12/2002 17:36:20 Posts: 4912 Location: Oxfordshire, England, UK
Posted: Wed Sep 08, 2004 3:49 pm Post subject: |
Are you running PPC 2002?
If you are then you may want to install CheckPOInt 2.02 which installs files for PPC2002 that Postcode can also use.
Garmin Camper 770 LMT-D |
Posted: Wed Sep 08, 2004 4:47 pm Post subject: Still not working |
Yes I have tried lots of soft starts and a compleat reload.
If you mean what settings do i have the TT gps at? There the same as before (Tom Tom GPS (Ipaq Sleeve) and GPS receiver.
Or do you another GPS Driver?
I am running PPC2002 2.10 and I had CheckPoint on there as well because I had the speed camera softwear as well. |
Posted: Wed Sep 08, 2004 4:55 pm Post subject: |
Try re-installing the GPS Jacket Driver, this should be on the CD that came with the original bundle (is it HP's iNS System?) as TT3 does not natively support the Navman/iNS Jackets unless you use the driver that Navman/HP iNS supply.
If you don't have the CD, for the HP iNS System, use the driver available here or alternatively for the Navman Jacket use this one. _________________ Darren Griffin |
Posted: Wed Sep 08, 2004 5:26 pm Post subject: YEEP EEEEEEEEE |
Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
So what happened there then?
Forget it I am very Happy Now
I loaded the Ipaq CD on and way it went. But what gets me is why It did it.
Right will try again only one more think the folder for ukpostcodes, Is it ukpostcode or 'ukpostcode'
Or any think else.
Thank you again
Ferd32 |
moggy Regular Visitor
Posted: Fri Sep 10, 2004 5:52 pm Post subject: |
the folder should be ukpostcode
just as its spelt without the apostrophies |
