Pocket GPS World :: View topic - POIS
POIS
Goto page Previous  1, 2
Coaster2
PostPosted: Sun Jan 02, 2022 9:53 am    Post subject: Reply with quote
dales wrote:
You should listen to sussamb, I think. Very Happy
On my Garmin 2599. I get icons for knives and forks (etc) on the screen from the (Foursquare) POIs which are effectively built into the map.
The way to hide them is as sussamb has said.
On my Garmin, I go into settings for Map & Vehicle ... Map Layers and uncheck Up Ahead and press Save.
Dales.
I tried that Dales and it hid all the knives and forks icons but, unfortunately, it his the speed cameras too.
Coaster2
PostPosted: Sun Jan 02, 2022 9:24 pm    Post subject: Reply with quote
Dales.
Thanks Dales but I've done exactly that and I lose the knives and forks but I also lose the speed cameras.
dales
PostPosted: Sun Jan 02, 2022 11:35 pm    Post subject: Reply with quote
Well, Coaster2, that doesn't sound quite right to me, because these POI types are stored in different places, and they are each disabled in their own different ways.
The 'Big Blue Icon' knives & forks (ie Restaurants) POIs are effectively built into the map; and they are turned on or off by disabling Up Ahead in the Map Layers.
Whereas the PGPSW speed camera POIs are stored in the Garmin's POI folder. And if they are present there, they are turned on or off by disabling Custom POIs in Proximity Alerts.
My own Garmin works just fine, with Up Ahead disabled and Custom POIs enabled.
If I were you, I would have another go, and methodically.
Load your PGPSW speed cameras with PoiLoader. (There should now be a .gpi file with today's date in the Garmin's POI folder).
Make sure that Custom POIs are Enabled in Proximity Alerts.
Now disable Up Ahead in the Map Layers, and that should do it.
NB At any stage, you can do a demo run to check things out.
In Navigation, press GPS Simulator. Then set a dummy route past some Restaurants and PGPSW speed cameras, and check out your results !
Dales
Coaster2
PostPosted: Mon Jan 03, 2022 3:59 pm    Post subject: Reply with quote
Having followed your instructions to the letter I find that, while all the knives and forks icons disappear, so do all the camera icons. However, the cameras are still working as I still get the audio alerts. I'll settle for that.
Many thanks for all the help.
PostPosted: Mon Jan 03, 2022 5:10 pm    Post subject: Reply with quote
Missing camera icons is another fix.
Follow my 'spoon feed' tutorial to ensure you have all the file links.
Satnav:
Car Average MPG :
Coaster2
PostPosted: Mon Jan 03, 2022 6:38 pm    Post subject: Reply with quote
Where do I find it please?
PostPosted: Tue Jan 04, 2022 5:53 am    Post subject: Reply with quote
In the Garmin forum here.
It's near the top as a sticky and clearly labelled 'spoon feed'
Satnav:
Car Average MPG :
Page 2 of 2
