Pocket GPS World :: View topic - Refuses to start up.
Goto page 1, 2, 3  Next
topref
PostPosted: Sun May 14, 2017 11:51 pm    Post subject: Refuses to start up. Reply with quote
My 2699 LMT-D hasn't been used for some weeks and just lost all its charge in that time. When I connect it to my laptop, it isn't recognised and refuses to start up.
I left it connected to the mains all night but it didn't charge. This afternoon, I connected it to the cars' cigarette socket but it didn't charge there either.
Anyone have any ideas?
PhilHornby
PostPosted: Mon May 15, 2017 1:26 am    Post subject: Re: Refuses to start up. Reply with quote
Damaged mini/micro USB socket? - try applying gentle sideways pressure on plug to see if it makes contact.
I'm not familiar with the 2699, but I assume it doesn't have a dedicated charging connection via a car cradle?
PostPosted: Mon May 15, 2017 6:40 am    Post subject: Reply with quote
If the battery is completely flat it may take a while to get enough charge to work. If you can use a wall socket and leave it charging overnight.
I'm surprised though that the battery should discharge that quickly if the device isn't being used, so if charging doesn't work call Product Support for help.
topref
PostPosted: Mon May 15, 2017 7:09 am    Post subject: Reply with quote
I was also very surprised that it discharged too. I did leave it plugged in overnight but to no avail. Will do the same later on today to see if it jolts it into action.
PostPosted: Mon May 15, 2017 7:12 am    Post subject: Reply with quote
Plugged into what though? A normal USB port generally won't provide enough power. Can also go to sleep in which case no power.
If your car socket does that stay powered on?
PostPosted: Mon May 15, 2017 7:36 am    Post subject: Reply with quote
Probably won't work, but, if plugged into a PC does the PC bing bong to acknowledge the device connection.
If theres a cable or socket issue then it definately won't work.
Satnav:
Car Average MPG :
PostPosted: Mon May 15, 2017 8:13 am    Post subject: Reply with quote
topref did say several weeks.
@topref. Did you switch it off, or just put it in standby?
PostPosted: Mon May 15, 2017 8:49 am    Post subject: Reply with quote
I've had mine off charge for a few months and it didn't fully discharge. Strange.
Satnav:
Car Average MPG :
PostPosted: Mon May 15, 2017 9:04 am    Post subject: Reply with quote
But was that with it on standby or switched off?
PostPosted: Mon May 15, 2017 9:26 am    Post subject: Reply with quote
Even so ... but you're right, if in standby that would have done it Very Happy
PostPosted: Mon May 15, 2017 10:32 am    Post subject: Reply with quote
Switched off, like me
Satnav:
Car Average MPG :
topref
PostPosted: Mon May 15, 2017 9:53 pm    Post subject: Reply with quote
I have a SKROSS World Adapter which has two USB outlets and have tried both but it didn't charge the unit.
I also sat in the car with the engine running for quite some time yesterday but even that didn't work. It's not the cable as I used two different ones.
In answer to other responses (which I an very grateful for),
I always switch it off after downloading the camera alerts.
The PC doesn't recognise the unit when I connect it.
It is currently connected to the mains and will remain so overnight.
If there is still no change in the morning, I will contact Garmin.
PostPosted: Mon May 15, 2017 10:22 pm    Post subject: Reply with quote
Will be good to hear what they suggest/say.
topref
PostPosted: Mon May 15, 2017 10:23 pm    Post subject: Reply with quote
Watch this space!
marksfish
PostPosted: Tue May 16, 2017 8:07 am    Post subject: Reply with quote
I am no expert, but have you tried holding the on/ off button in and seeing if that invokes a response?
Mark
Page 1 of 3
22.051 (01 May 24)
