Newsletter
Pocket GPS World :: View topic - Mercedes MY17 Garmin Map Pilot - Alerts in Chinese?
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9
PostPosted: Fri Aug 31, 2018 4:19 am    Post subject: Reply with quote
Privateer wrote:
Hi Schouten,
On the size of icons, I tend to use 24x24 which is the Size TomTom used to use before they stopped showing icons on their SatNav products.
I think think that the Garmin builtin icons are about 62x62. I’ve created icons of that size and they work well, if not a little large, on my Garmin 770. Thumbs Up
Just spotted this ..... Garmin default icons are 22x22 but 44x44 work better for the 5" units.
I'm finding the 44's a bit too small on the 6" units though so 62x62 is a good call if they work.
Wonder if there is a utility to upsize them without having to do a manual job that will take ages.
Satnav:
Schouten
PostPosted: Sun Sep 02, 2018 9:13 am    Post subject: Reply with quote
@Kremmen @Privateer
Thanks for your replies. I did resolve this eventually though I can't remember how! 44x44 work ok, except now I don't get the Specs icons showing at all just the notification on the banner and the occasional bong.
I've tried specs at 22x22 and 44x44 but without luck. I doubt it's an icon problem and must be the relationship between the spec and spec_20 files. But I can't see the problem, the file contents are identical as the spec_20 is simply a rename of the spec. All others files work and display fine and are complied in the same way.
It has worked.
More digging!
Terry
PostPosted: Sun Sep 02, 2018 12:22 pm    Post subject: Reply with quote
Very odd, presumably you can see the full filenames so you can double check the Specs ones ?
Failing that, download my Converter as that will show any mismatched files on loading.
Satnav:
Schouten
PostPosted: Mon Sep 03, 2018 8:34 am    Post subject: Reply with quote
@Kremmen
Thanks, yes full filename is identical, contents look the same as its just a "save as" for the _20 file. Strange that the other ones (Gat, Red etc) work fine.
I have a MAC with no Excel but use an open source Excel "lookalike" (LibreOffice Calc) so unfortunately your converter isn't an option.
I'll keep playing around with it.
Page 9 of 9
20.054 (25 May 22)
