Oscargrouch Regular Visitor
Posted: Sun Oct 25, 2015 11:37 pm Post subject: |
M8TJT wrote: | Jeez. I know what a file with a .prev extension looks like, and if you say you have them, I believe you. No need to include a picture for my benefit which takes up a load of space and is far too big for the forum layout, screws it up and is contrary to forum guidelines. Please edit it out. |
As you can see, it has been removed, must have misinterpreted your previous post when you wrote; 'Haven't a clue what the .prev files are. Csv converter doesn't generate them'. |
M8TJT The Other Tired Old Man
Posted: Mon Oct 26, 2015 1:22 am Post subject: |
I was not aware that kremmen's prog generated them as I have not seen them before. . Wherja get that imoticon?
@kremmen. Is this new, or have they 'always' been there as I haven't noticed them? |
Kremmen Pocket GPS Verifier
Posted: Mon Oct 26, 2015 5:46 am Post subject: |
They've always been there. At least 3 years.
At the top of the Converter menu bar is a 'new camera' option. That uses the .prev fiies to create some new .csv files that can be loaded into MapPoint to see where they all are.
TBH I've not used it for ages so probably a removal candidate if it's causing issues.
I called them .prev because they are a direct copy of the current .csv files before they get replaced with .gpx files. When the new set are downloaded it's easy to compare against each 'previous' file to identify the changes. _________________ Satnav:
Car Average MPG :
Posted: Mon Oct 26, 2015 9:21 am Post subject: |
Kremmen wrote: | TBH I've not used it for ages so probably a removal candidate if it's causing issues. | They are not causing issues. It's just that for some obscure reason, I haven't noticed them before. Not quite sure why. It isn't as if there is just one hiding amongst all the others is it. Not having noticed them before in my working folder was why I erroneously suggested that it wasn't CSV converter that was putting them there. |
Posted: Mon Oct 26, 2015 9:40 am Post subject: |
Talking of smileys I've been trying to find an appropriate one for here.
Car Average MPG :
Posted: Wed Oct 28, 2015 12:03 am Post subject: |
Kremmen wrote: | Talking of smileys I've been trying to find an appropriate one for here.
Posted: Wed Nov 04, 2015 3:50 am Post subject: |
@ Kremmen: What triggers the 'over speed' warnings? As when I have that activated it seems to always give the warning to 'slow down' even doing 25 mph in a 30 mph zone, should this be 'check your speed' instead?... |
Posted: Wed Nov 04, 2015 6:40 am Post subject: |
The overspeed function just uses Garmins own built in intelligence.
Can you have a look in one of the GPX files (Windows Notepad will do) and post one of the description lines ID's.
What I'm expecting is something like:
Gatso10#50 (for the mandatory warning)
Gatso10@50 (for the overspeed warning)
For both lines, looking further across you will see the 'proximity' statement which is the distance in metres that they are triggered. _________________ Satnav:
Car Average MPG :
Posted: Wed Nov 04, 2015 11:46 am Post subject: |
Kremmen wrote: | The overspeed function just uses Garmins own built in intelligence.
For both lines, looking further across you will see the 'proximity' statement which is the distance in metres that they are triggered. |
Forum didn't like me trying to post the code. Here is the link to my word doc in DropBox.. https://www.dropbox.com/s/g0913beqqh6t1q9/GPX%20Description%20Code.docx?dl=0 |
Posted: Wed Nov 04, 2015 12:57 pm Post subject: |
All I'm getting is one single line for camera 46 which is a mandatory alert at 223 metres.
I'll have a look on the PC later in case the download truncated it. _________________ Satnav:
Car Average MPG :
Posted: Wed Nov 04, 2015 1:04 pm Post subject: |
Kremmen wrote: | All I'm getting is one single line for camera 46 which is a mandatory alert at 223 metres.
I'll have a look on the PC later in case the download truncated it. |
Ooops, that's all I saved, I will replace it with the entire GPX File for the 50 Gatso in 5 minutes...Thanks. |
Posted: Wed Nov 04, 2015 2:13 pm Post subject: |
@Kremmen, I do have a separate Over Speed GPX file where the proximity is 335 as opposed to 223 as on the Gatso 50 GPX set. Don't know if this could be of relevance.. |
Posted: Wed Nov 04, 2015 4:22 pm Post subject: |
Ah
Could be.
I don't know how Garmins logic works exactly but having the overspeed.gpx file alert you before the mandatory one could be relevent.
My successful testing has always been with the overspeed kicking in after I've had the mandatory one.
What you've got is the overspeed warning quite some way from the camera so may be influencing numerous warnings. _________________ Satnav:
Car Average MPG :
