Pocket GPS World :: View topic - .ogg files
.ogg files
GaryL
PostPosted: Thu Dec 29, 2011 5:41 pm    Post subject: .ogg files Reply with quote
I have got new new 1005 added the poi's , BMP's and the sound files as per the insturctions.
http://www.pocketgpsworld.com/uksafetycameras-tomtom-nav3.php.
When you select the sound effect does it select the correct sound file by default as I am not given any option to select any files.
PostPosted: Thu Dec 29, 2011 5:52 pm    Post subject: Reply with quote
Yes it does, (assuming you have left the file names the same).
Maybe we need to tweak the instructions a bit to make that clearer.
In the NAV2 model instructions here it says:
4. You should now be asked to select the warning distance, followed by the Warn Only if POI on route – please set-up these options as per your normal preference, remember everyone will use different settings dependent upon how they use the device.
5. Note: You will be asked to choose a sound but will not be offered any options, this is normal. You will be asked 'Is this the sound you want?'. You should answer Yes on this screen. If you do, you will then see the warning distance screen and can proceed as normal.
On the NAV3 models, you don't get that odd question, but in the set-up it goes from "Choose a distance" then to "select Sound effect" then straight on to "Warn only if on route".
"Settling in nicely" ;-)
