Pocket GPS World :: View topic - Missing USB Port in Garmin 2360
biggles
PostPosted: Mon Jan 02, 2012 6:37 am    Post subject: Missing USB Port in Garmin 2360 Reply with quote
I bought a Garmin 2360LT 30/12. Due a number of hiccups Garmin offered to replace it. Subsequently I exchanged today(02/1) the original for another 2360LT.
Strangely the replacement has only 1 USB port which is a micro USB port. The original had two a micro and a normal mini USB port??? I now cannot charge the unit using a Garmin 240volt charger as it has the normal mini USB male fitting. This means I cannot charge the GPS unless it is charged by the car.
How many USB ports should I have on this model?
Wal
PostPosted: Mon Jan 02, 2012 12:35 pm    Post subject: Reply with quote
Are you sure it's different on the unit itself?
According to the manual for that series, there is a mini USB on the mount and a micro USB on the device itself
This is the same as on some recent TomTom models. There seems to be a move to standardise on micro-USB in the future and this is the first stage.
"Settling in nicely" ;-)
biggles
PostPosted: Mon Jan 02, 2012 9:46 pm    Post subject: Missing USB Port in Garmin 2360 Reply with quote
Thanks Andy, much appreciated. Seems the original example I had was an interim version with a mini and micro socket in the body of the device. You have nailed the answer to the problem. All I have now to do is bring the mount and GPS to the house and connect to the 240 volt charger IF the battery needs charging this way.
PostPosted: Tue Jan 03, 2012 1:45 am    Post subject: Reply with quote
You could also try a search on Google, Amazon or eBay for "mini to micro usb adapter". They are only a couple of pounds.
Make sure you get one going from mini to micro though! The other way round seems more common.
biggles
PostPosted: Tue Jan 03, 2012 4:58 am    Post subject: Mini to Micro Reply with quote
Thanks, I had a browse and found nothing in ebay or Amazon. No great effort to bring in the unit and charge at 240V on occasion.
Wal
22.053 (15 May 24)
