MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15145 Location: Bradford, West Yorkshire
Posted: Mon Oct 10, 2011 6:59 am Post subject: |
Kremmen wrote: | A bit cumbersome but I have an option to remove 'duplicate' cameras. I did it to remove the ones on motorways where they are on the same gantries but opposite carriageways:
Unfortunately the HTML checker won't let me post the code |
but how can it differentiate between a single camera that is 'duplicated' and a site where there are actually 2 cameras either side?
MaFt |
DennisN Tired Old Man
Posted: Mon Oct 10, 2011 7:59 am Post subject: |
I agree with MaFt's comment, same gantry but opposite carriageways is NOT duplication. Also what about sites like this? _________________ Dennis
Two of them are obesiting!! |
M8TJT The Other Tired Old Man
Posted: Mon Oct 10, 2011 10:21 am Post subject: |
Not having either a TT or a Garmin, I can't understand the problem that Kremmen has with the 'dummy' duplicate cameras. Do they give a double alert or what? Surely if they are both in more or less the same place, this won't cause a problem?
Why does Kremmen find it an advantage to remove one of the 'duplicates'? Presumably removing one of the real cams as per the aforementioned two real cam examples, would also cause him no problem with his device not alerting.
In Dennis' linked example of two cams and one of them were removed, surely a non directional device would warn of the one remaining in the database regardless of his direction of travel, and a directional device (i.e. iGO) would warn in either direction so long as the one cam left at the location is logged as reversible.
Obviously in Dennis' examples of where there ARE two cams or the Gantry, there must be two cams shown, othewise we would get complaints about real cams not being in the database. We seem to have enough problems with known dummys not being in the database let alone real cams. |
willmow Regular Visitor
Posted: Mon Oct 10, 2011 11:33 am Post subject: |
One of the confusions is that some reversible cameras are marked as such in the interactive map, yet others in a similar situation are marked as two separate cameras (I'd upload two photos but I don't know how! - can someone elucidate...?). |
Oldboy Pocket GPS Moderator
Posted: Mon Oct 10, 2011 11:38 am Post subject: |
Have a look at This Guide.
Written better than I could do. _________________ Richard
Kremmen Pocket GPS Verifier
Posted: Mon Oct 10, 2011 12:19 pm Post subject: |
MaFt wrote: | Kremmen wrote: | A bit cumbersome but I have an option to remove 'duplicate' cameras. I did it to remove the ones on motorways where they are on the same gantries but opposite carriageways:
MaFt |
All I'm doing is assuming that any 2 cameras that are within 0.001 of a mile of each other are duplicates.
By this method I'm eliminating the scenario posted here plus the motorway cameras on the same gantry.
I can supply a complete list of all the cameras I'm omitting via this method if it will help. _________________ Satnav:
Car Average MPG :
Posted: Mon Oct 10, 2011 2:26 pm Post subject: |
But why are you doing this? What problems does it eliminate? What problems do motorway gantry cams pose?
I am only asking as I don't understand what the problem is.
Luckily, whatever the problem is, it does not affect me |
Posted: Mon Oct 10, 2011 2:31 pm Post subject: |
willmow wrote: | One of the confusions is that some reversible cameras are marked as such in the interactive map, yet others in a similar situation are marked as two separate cameras | It was only after it was found out that reversible cams gave the problem on dual carriageways that the idea of putting in the duplicate came about. The one that does not have the duplicate may have been put in the database before this time, or the need for a duplicate could just have been overlooked.
Camera numbers might be a helpful. |
Andy_P Pocket GPS Moderator
M8TJT wrote: | Not having either a TT or a Garmin, I can't understand the problem that Kremmen has with the 'dummy' duplicate cameras. Do they give a double alert or what? |
Yes they do...
On my TomToms, they try to be helpful by not playing two alert warnings on top of each other, so they play one after the other.
That means I get an alert as I approach the camera as normal, but then, just as I go past it, I'll get another one for the second entry.
I can easily live with it, but it would be nice if it didn't happen.
willmow wrote: |
One of the confusions is that some reversible cameras are marked as such in the interactive map, yet others in a similar situation are marked as two separate cameras. |
That will be down to simple human error. Under current rules, I think those two examples should both be shown with TWO icons, one on each carriageway. MaFt?
Kremmen wrote: |
By this method I'm eliminating the scenario posted here plus the motorway cameras on the same gantry. |
BAD Assumption!!!
1. There are loads of examples where two real cameras are within a few feet of each other - Do you really want to lose warnings for those?
2. GATSO:414 on the A416 in N.London is one example where the location of a single camera on a slip road covers both the slip road and the main carriageway .
But if you only mark the actual location of the camera, you do NOT get a warning for it if you are driving north on the main road. So we put an additional icon (GATSO:65105) in that position. Do you want to lose that warning too?
3. I still can't understand why you would ever want to delete the entries for real, individual cameras covering the two sides of a motorway where those cameras happen to be on the same gantry.
Any systems which CAN do directional warnings would need both entries,
.....Most that can't would still work best with them showing,
.....and without them hundreds of people would start re-reporting the "missing" cameras.
Seems a bad idea all round to me! _________________ "Settling in nicely" ;-) |
Posted: Mon Oct 10, 2011 2:53 pm Post subject: |
Thanks for that explanation Andy. I wonder which device Kremmen has? |
Posted: Mon Oct 10, 2011 5:50 pm Post subject: |
Previous posts indicate Garmin. _________________ Dennis
Posted: Mon Oct 10, 2011 11:48 pm Post subject: |
It's Garmin. He wrote some software similar to Ash10's and CBROM's that customises the database warnings for use with POI Loader. The 'remove duplicates' is an option in that for users to decide whether they want to or not.
MaFt |
Posted: Tue Oct 11, 2011 6:24 am Post subject: |
M8TJT wrote: | But why are you doing this? What problems does it eliminate? What problems do motorway gantry cams pose?
I travel the M25 western section daily and originally I was finding that for some reason my Garmin 2200 was producing 4 consecutive warnings for each variable speed camera when they were adjacent. The way the Garmin seems to work is that they 'stack up' the warnings so I was getting 4 back-to-back warnings taking up probably 20 - 30 seconds.
I made 2 changes to my CSV to GPX converter:
1) Change the variable limit within the GPX from zero to 70.
2) Remove these very close cameras.
I now only get a single approach warning, in each direction, for these adjacent cameras. _________________ Satnav:
Car Average MPG :
Posted: Tue Oct 11, 2011 9:48 am Post subject: |
Kremmen wrote: | I was getting 4 back-to-back warnings taking up probably 20 - 30 seconds. | Ah, now I realy understand the problem. That would seriously P me off as well, and I would probably do the same as you.
Kremmen wrote: | 1) Change the variable limit within the GPX from zero to 70. | I suppose, if left at zero MPH, these would give you a double warning regardless of speed. And after all, there are some large speed limit signs reminding you of the reuced speed limit just before the cam
Andy_P wrote: | 2. GATSO:414 on the A416 in N.London is one example where the location of a single camera on a slip road covers both the slip road and the main carriageway .
But if you only mark the actual location of the camera, you do NOT get a warning for it if you are driving north on the main road. So we put an additional icon (GATSO:65105) in that position. Do you want to lose that warning too? | Is this how some TTs work? My guess, based on what Kremmen has said, is that they would give double alert on his Garmin regardless of being on the main or slip road?
If this and my previous assumptions, based on Kremmen's description of the problem are correct, I'm surprised that more Garmin users have not complained about this 'feature' of our DB on Garmins. |
